Docker & McAfee on Windows Server
mce
Excel Version: 2013 2016
Post by mce » Fri May 03, 2019 4:43 am
We are having trouble with installing PAW on Docker on a Windows 2016 Server that McAfee installed.
There is a note from McAfee in https://kc.mcafee.com/corporate/index?p ... id=KB90041 about this issue.
But I just wanted to check if anyone managed to get it working? Are there any workaround to this solution without removing McAfee? Is there any config or exception that we can make in McAfee to avoid having this issue?
Any comment or help will be appreciated. Thanks in advance.
macsir
Version: PAL 2.0.8
Re: Docker & McAfee on Windows Server
Post by macsir » Fri May 03, 2019 5:01 am
What is your issue anyway?
mce
Post by mce » Fri May 03, 2019 5:56 am
After we execure start.ps1, we keep getting "PAW Loading Image Error - Access is Denied" error.
But in different environments we got different errors at different stages.
blackhawk
Post by blackhawk » Sat May 04, 2019 4:40 pm
I have not specifically had that error, but I can tell you McAfee and PAW/Docker do not play well together. We are consistently seeing 80-100% CPU on McAfee services and oftentimes it prevents PAW from even starting all of the services...due to timeouts.
I have never had great experiences with McAfee. In my opinion it is one of the most resource intensive and intrusive virus software I have ever seen. Norton at one point claimed that title, but now it seems McAfee has taken the lead.
While I think AV apps have their place, I generally avoid using them on servers that are data providers or internal web application servers. #1, the users don't access them directly anyway. #2, they are not externally exposed to the internet. Yeah, I am sure there is someone out there who will argue against this, but if a virus comes through your main lines of defense (routers, firewalls, end-users machines, vpn), likely the AV on the server won't do any good anyway. It has already penetrated your primary barriers; meaning your current AV couldn't detect it yet anyway.
If you can't disable or remove McAfee, see if you can temporarily turn it off while startup and then turn it back on afterwards. This has worked for us (as we have had no luck with IT in removing it from the server).
mce
Post by mce » Sun May 05, 2019 10:29 pm
Are you sure that disabling it guarantees that McAfee will not prevent PAW or Docker? We tried disabling it temporarily, but still got the same error.
Does it work in your environment, by only disabling McAfee at installation stage and keeping it on on regular server PROD time?
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble » Mon May 06, 2019 1:24 pm
Disabling AV software may not be effective as often file system drivers are installed at boot time.
You can run the
fltmc
command to see active filter drivers.
blackhawk
Post by blackhawk » Mon May 06, 2019 4:26 pm
For us, it is not at install time (I think we have put in the filters for that part), it is primarily at startup time for PAW.
Anytime the PAW server needs to be restarted or if we have to upgrade it or just reboot, we run into this issue. What we end up doing is disabling the scanner, and that (sometimes) gives us enough CPU breather to get the PAW containers up and running without timeout problems. It doesn't always work, but it does work more often than not. I wish we could remove McAfee altogether.
Running PAW in general on a Windows host, I am increasingly recommending against for our customers. I find that the linux version is SOOO much faster, less resource intensive, just more nimble overall. It also is less prone to these kinds of issues. That said, you have to be able to support a linux OS in your server ecosystem, and that is where we run into challenges with some customers. If you can support it, I would definitely consider going the linux route.
One other thing to note....as of Windows 2019, containerized services are now part of the OS and no longer require a Docker EE license to be purchased separately. Unfortunately only PA (TM1 Server) 2.0.7 supports Windows 2019....PAW does not....the one that could really use Windows 2019. I checked with product development team, and Windows 2019 for PAW is not even on the roadmap yet. I would like to see if Windows 2019 plays better with PAW than 2016 with Docker EE, but until then, if you can go to linux, you will find it much less problematic.
Good luck!
Version: 10.2.2., PAW
Post by Steve Rowe » Tue May 07, 2019 10:01 am
Hi Blackhawk,
Just some queries / comments.
Our understanding is that the Windows Server OS 2016 does not require an additional docker licence. Do you have anything definitive to the contrary? (my reference the end of this page but plenty of other places mention an agreement being in place.
What performance testing have you done on a windows vs Linux loadout? We've done some and found that whilst linux is better it is pretty marginal. Not enough to recommend one environment over the other unless you are talking large scale? Agree there is certainly a perception that Linux is much better but when we tested we couldn't demonstrate it. (Except for logging in which on windows takes longer).
Linux then attracts the additional licence costs of Docker EE which seems to be the major differentiator between the approaches.
mce
Post by mce » Tue May 21, 2019 7:11 am
We considered running PAW on Linux Red Hat for a client, and checked with Docker about Docker EE licensing. They said it costs 500$ per core per year with minimum purchase requirement of 40 cores. This means 20.000$ per year minimum we have to pay to Docker to be able to use PAW on a Linux Red Hat Server with Docker EE. On long term, this means paying more license fee to Docker than we pay to IBM for PAW. Did anyone find or offer a solution to this problem?
Should not it be the case that Docker EE licenses must have been included in IBM PA licenses? IBM can probably make a good deal with Docker to cover Docker EE licensing for use with PAW.
Post by Steve Rowe » Tue May 21, 2019 7:25 am
Through the docker website the minimum core count is 5, so sounds like someone is trying to gouge you? Its still more costs than it should be (i.e. =0).
Post by Steve Rowe » Tue May 21, 2019 9:17 am
Well I was 100% sure of my facts on this but I'm now struggling to find earlier references.
This may have something to do with it https://searchitoperations.techtarget.c ... questions
I'm not sure this is the same product as Docker EE but is at least indicative that the minimum license count was 5.
https://hub.docker.com/pricing
Bakkone
Post by Bakkone » Tue May 21, 2019 9:40 am
Couldn't you just run the CE edition? Do you really need the EE edition?
Also new editions of Windows Server will actually have a little Linux core in them. Its going to be interesting to see how this affects deployment. I want to think it will allow for a best of both worlds.
Post by Steve Rowe » Tue May 21, 2019 10:00 am
Hi Bakkone, you could run CE but it is not formally supported. When IBM removed support for Ubuntu this also removed support Docker CE (since RHEL only supports Docker EE).
FYI this is the link for docker ee pricing you need a log in though.
https://hub.docker.com/editions/enterpr ... l/purchase
From memory when you get to the last page you can drop the core count from the default of 10 down to 5.
mce
Post by mce » Tue May 21, 2019 11:29 am
Hi Steve, This is Docker hup pricing. As per my understanding this is their cloud offering. Hence the prices there are offered for cloud hosted docker as per my understanding. I was looking for on-premise license.
Post by Steve Rowe » Tue May 21, 2019 1:17 pm
Hi mce, Did you log-in and fill in the forms? I don't think that just because the path starts with hub, this relates to hub specifically.
For example this page is talking about RHEL on prem installs (I think!)
https://hub.docker.com/editions/enterpr ... erver-rhel
Ajay
Version: 10.2.0
Post by Ajay » Sun Mar 15, 2020 9:57 pm
@Mce
Did you manage to get Docker working with McAfee, on WinSer 2016 ? or did you have to another route ?
We're in the same hell hole at the moment, trying to figure this one out, so any help would be appreciated
Ajay
10.2.0, w2008R2 OS Enterprise Edition, 1TB HD, 384GB RAM, MS Excel 2016, Cognos 10 BI
Version: PAL 2.0.8
Excel Version: Office 365 - latest
Post by Wim Gielis » Mon Mar 16, 2020 12:53 am
There’s a McAfee tech note, do not use it with Docker.
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 model with AutoHotKey as a service or application
Ajay
Version: 10.2.0
Post by Ajay » Mon Mar 16, 2020 10:04 am
Thanks Wim.
We are seeing conflicting information in these two URLs.
McAfee basically telling us that we can't use Endpoint 10.x because it is not supported
and Docker tell us it is !!!!
https://success.docker.com/article/endp ... containers
All very confusing....who to believe ?
