TM1Web Slice issue on Windows 10
DaS
Post by DaS » Wed Apr 10, 2019 9:10 am
Hi all, I'm facing an issue with a user when she performs a slice from tm1 web. after the slice, the form opens from Office 365 and not from Perspectives.
the only way to open it in Perspectives, is saving the form and use the open function on Perpsectives.
she has the following configuration:
-windows 10
-Perspectives 10.2.2 FP7
-Office 365
the issue arises using Firefox, Explorer and Edge.
does anybody faced the same problem or have an idea for a possible resolution?
thanks for your help
davide
orlando
Version: PAL 2.0
Re: TM1Web Slice issue on Windows 10
Post by orlando » Mon Apr 15, 2019 1:21 pm
Hi davide,
i would say, that this is a total normal behavior, beause you're exporting an xlsx file and not an extra file for perspectives.
what you could do is:
Add perspectives (tm1p.xla) to the add-ins that start with excel.
then your user can use the sheet (after login to tm1, of course).
best regards
orlando
