Manage Rights when a big chunk of elements are deleted
Paul-TM1
Post by Paul-TM1 » Mon Feb 25, 2019 7:47 pm
In 10.2.2, when ever I delete a chunk of elements from the "Approval hierarchy" dimension and apply manage Rights, it takes 4-5 hours to complete the process in multi threaded configuration.
 <deployment maxThreads="4"/>
Normal manage rights with 4 threads takes about an hour. What happens in this 4-5 hours is a mystery. Can someone please explain the long process? What is different?
In PA 2.0.6, I deleted some elements and started manage rights and it's running since 3 days. I see the same processes running and it's not hung. Can any one suggest what could be done?
"}tp_get_top_node"
}tp_util_is_in_subset"
"}tp_get_parent_in_subset"
Paul.
Elessar
OLAP Product: TM1 10.2.2, PA 2.0.9
Re: Manage Rights when a big chunk of elements are deleted
Post by Elessar » Wed Feb 27, 2019 8:21 am
How long does it take to do a SecurityRefresh on your server?
Sorry for my English ;)
Paul-TM1
Post by Paul-TM1 » Wed Feb 27, 2019 4:45 pm
Hi Elessar,
Thanks for the reply.
It takes about an hour for SecurityRefresh normally. On PA 2.0.4 and 2.0.6, it takes about 1.5 hours. Since it was taking longer, I asked IBM and they gave us an interim fix and that does not complete securityRefresh. It stops before completing with an error as below.
[Default Executor-thread-22303] ERROR (getApplicationSecurity) com.ibm.cognos.pmpsvc.PMPService - getApplicationSecurity connection lost exception raised.
Any help is appreciated.
Thanks.
Post by lotsaram » Wed Feb 27, 2019 9:44 pm
Oh my!
I have worked on some pretty huge models (and talking security not just data; thousands of users, thousands of groups) but I have never seen SecurityRefresh take longer than about 5 - 10 minutes. In most models, even very large ones, it is considerably less.
A very good argument for getting rid of the Contributor application.
ykud
Post by ykud » Thu Feb 28, 2019 12:59 am
In my experience, the longest part is usually the }tp_rights_update_RDCLS_static_rights process that does a really huge loop over the groups / approval nodes / control dimension intersections and copies the rule calculated rights value to a 'static' slice. Because it does it for every cube in your application and you maybe have a lot of groups / approval elements / elements in control dimension -- it will take ages to scan through it.
The parallel processing 'chunks' this process into parts, but doesn't really change the overall approach.
You can decrease the search space by pruning unnecessary groups / control elements.
You can also get hacky and optimise this process to look at only the applicable group / control dimension element subset for applications to reduce the time quite a bit. For example, looping through only the applicable 100 groups for an application instead of a 1000 in total would speed up the execution by a factor of 10 :) But this is a bit of an exercise in coding and you'd be changing the 'out of the box' process.
Y
ykud
Post by ykud » Thu Feb 28, 2019 1:07 am
Hi Elessar,
Really try and see if you can remove some of the user groups you're having, it will make everything a lot faster :)
And it might be worth looking into setting PrivilegeGenerationOptimization to T and writing feeders for Cell Security rules, it improves cell security rule processing time.
Elessar
Post by Elessar » Thu Feb 28, 2019 7:16 am
Cellsecurity cubes are calculated each time when user reads data, they do not affect SecurityRefresh.
1,5h is really long for SecurityRefresh. Do you have rules in ElementSecurity cubes for large dimensions? There is a good practice to update ElementSecurity cubes for dimensions with >500 elements using TI, so that their rules will not be calculated during SecurityRefresh.
And another thing: how large is your }tp_jobs dimension? It can also affect application maintenance time:
https://www-01.ibm.com/support/docview. ... wg21987687
Version: PAL 2.0.8
Post by Wim Gielis » Thu Feb 28, 2019 10:25 am
Also you can have Cell Security cubes with less dimensions than the original cubes. Maybe this helps as well.
Newest blog article: Selecting elements in the Subset Editor quickly
Paul-TM1
Post by Paul-TM1 » Fri Mar 01, 2019 9:58 pm
Thanks for all your ideas Ykud, Elessar, Lotsaram and Wim G.
I tried to run the ideas presented by Elessar and it did not get a positive result. May be a server restart might provide. I will be trying other ideas as I proceed.
Thanks again for your inputs.
Paul.
Catherine
Version: 10.2.2 - PA
Post by Catherine » Thu Jun 06, 2019 1:33 pm
Hi Wim,
Please, could you tell me more about this ?
From which version is it possible ? I saw it was possible through Performance modeler... In 10.2.2, using Perspectives, when I right click on a cube to implement cell security, it creates a control cube with all dimensions + }Groups dimensions. I have no choice regarding dimensions.
Thanks in advance
Post by David Usherwood » Thu Jun 06, 2019 2:52 pm
It's the TI command CellSecurityCubeCreate, supported in 10.2.something onwards:
https://www.tm1forum.com/viewtopic.php?f=3&t=11423&p=54152#p54152
Catherine
Post by Catherine » Thu Jun 06, 2019 4:00 pm
Thank you very much !
I will test it very soon.
