Ascii Quote Fun and Games
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Post by jim wood » Tue Feb 05, 2019 3:02 pm
Guys,
I'm trying to move awkward data between cubes and this includes free comment fields. The fields contain all kinds of crap so I can't use the usual delimiters as I'm exporting it to file first. I have therefore gone for the Ascii quote character set as Char(186) which then looks like this:
The process exports the data to file as expected without issue. The same process then loads the data in to the other cube. The problem is that the process doesn't seem to like the quote character. I get the following errors:
I have made sure that the source ascii quote is set correctly yet the process still doesn't seem to like it.
Any idea why guys?
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
jim wood
Version: TM1 10.2.2
Re: Ascii Quote Fun and Games
Post by jim wood » Tue Feb 05, 2019 3:37 pm
Looks like it may have something to do with the extended Ascii character set. Looking at something else and will post back.
jim wood
Version: TM1 10.2.2
Post by jim wood » Tue Feb 05, 2019 3:58 pm
It was 100% because I was using an extended Ascii character 0186. Once I lowered it to character 94 everything worked as expected. It's interesting that the process itself recognized the extended character but the data tab part of the process did not,
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Post by Wim Gielis » Tue Feb 05, 2019 4:39 pm
I have seen strange cases in the past with extended Ascii characters and try to stay away from there.
Which includes French accents like é, è, ê too. Not sure if this is still an issue nowadays, I am talking about some 5 years ago.
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
jim wood
Version: TM1 10.2.2
Post by jim wood » Tue Feb 05, 2019 5:24 pm
We're still on 10.2.2 so it may have been fixed since.
paulsimon
Version: PA 2.0.5
Post by paulsimon » Tue Feb 05, 2019 8:29 pm
Hi Jim
You may already be doing this, but in the past when I had to write different languages (including chinese) to files and read them back, I did the following :
In the Prolog get the char set
vCharSet =  CellGetS( vInfoCube, 'Any', 'Character Set' ) ;
When writing to a file in the Data Tab you need something that will track the very first record being written :
IF( vDataRecCount = 1 ) ;
  # Before outputting anything to the main file,
  # we need to set the character set immediately before
  # the first output statement.
  SetOutputCharacterSet( vPathFile , vCharSet ) ;
  textoutput( vPathFile , 'Element' , 'Attr'  , 'OldVal' , 'NewVal' ) ;
ENDIF;
When reading from a file in the Prolog you need something like
SetInputCharacterSet( vCharSet ) ;
Andy Key
OLAP Product: TM1 CX
Version: 2-5 to 10-2-x
Excel Version: 2003 2007 2010 2013
Post by Andy Key » Wed Feb 06, 2019 3:07 am
If you're only writing the data out to a file so you can read it back in again, won't SetOutputEscapeDoubleQuote cover it? No need to use anything other than the standard double quote, although you can still choose something else if you want, it will double up whatever character you have as the ASCIIQuoteCharacter.
You're still stuck with the joys of things like embedded CR/LF though...
Andy Key
