PAW not working after network changes
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Re: PAW not working after network changes
Post by gtonkin » Tue Oct 09, 2018 2:23 pm
>docker ps -a returns the same result - just seems like the gateway has not installed.
Version: PAL 2.0.3
Post by gtonkin » Tue Oct 09, 2018 2:30 pm
Just re-ran scripts\paw.ps1:
PS C:\paw> scripts/paw.ps1
The IBMCognosGatewayURL variable is not set. Defaulting to a blank string.
Pulling social (pa-docker:5000/planninganalytics/social:1.0.50-windowsservercore)...
Get https://pa-docker:5000/v2/: dial tcp: lookup pa-docker: no such host
Execution failed with exit code 1
At C:\paw\scripts\init.ps1:58 char:13
+             throw "Execution failed with exit code $LASTEXITCODE"
    + CategoryInfo          : OperationStopped: (Execution failed with exit code 1:String) [], RuntimeException
    + FullyQualifiedErrorId : Execution failed with exit code 1
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble » Tue Oct 09, 2018 4:06 pm
If you ever see the "pulling" message then likely the images are not loaded (or got removed).
dharav9
Version: 10.3
Post by dharav9 » Wed Feb 13, 2019 2:29 am
I experienced the same issue earlier. We identified that port 80 might be open for other app. Port 80 is generic port number for many applications.
So we updated the PAW/CONFIG/Paw.ps1 file with $environment line to change port number. We changed to port 82 and run powershell as admin. Test the change in powershell by scripts/paw.ps1. PA-Gateway connected----done. Now re-start PAW => ./start.ps1
Everything works.
Hope it helps. Thank You
Dharav
Version: PAL 2.0.3
Post by gtonkin » Wed Feb 13, 2019 10:12 am
Thanks for the information - unfortunately in my case it did not appear to be something else on port 80 but will definitely add your comments to my ever-growing notes for the next time!
