Getting started with REST API (issue)
no_surrender
Post by no_surrender » Mon May 21, 2018 8:54 am
Hello all,
I have some issue trying to see this page http://tm1server:HTTPPortNumber/api/v1/$metadata or http://tm1server:HTTPPortNumber/api/v1/
The message that i get from my browsers is "This page can't be displayed"
What could be wrong?
I've try do it on 2 different servers and different tm1 instances.
Thank you.
Edward Stuart
Version: All
Excel Version: All
Re: Getting started with REST API (issue)
Post by Edward Stuart » Mon May 21, 2018 8:59 am
You will need to set the installation/ configuration details in the manual:
https://www.ibm.com/support/knowledgece ... stall.html
Specifically the httpportnumber
no_surrender
Post by no_surrender » Mon May 21, 2018 9:45 am
Of course, I've read it before asking here )
Post by tomok » Mon May 21, 2018 11:07 am
Did you literally try this address, http://tm1server:HTTPPortNumber/api/v1/$metadata, or did you substitute in the port number for the "HTTPPortNumber" part of the string?
no_surrender
Post by no_surrender » Mon May 21, 2018 11:18 am
I used real http port number and real server name
Edward Stuart
Version: All
Excel Version: All
Post by Edward Stuart » Mon May 21, 2018 12:30 pm
Can you give some further indications as to what you have tried, does the link work with localhost when on the server?
Request for assistance guidelines
no_surrender
Post by no_surrender » Tue May 22, 2018 10:57 am
I've done everything like in manual and tried that link. I've done it right on the server and remotely on my pc. I've tried different servers, different instances, different links (with full server name, short name, localhost)
Edward Stuart
Version: All
Excel Version: All
Post by Edward Stuart » Tue May 22, 2018 12:19 pm
Are the firewall ports open for port number 5895 or 5898?
Have you re-started the adminhost and verified the port number settings? What have you input for UseSSL?
http://localhost:5895/api/v1/Servers
https://localhost:5898/api/v1/Servers
What version of TM1 are you using, is it still 10.2.2? Which Fix pack? Which browser are you using? Which version? is it compatible? What operating system are you using? What version? These may or may not be relevant but "I've done everything like in manual" does not really help diagnose your error does it.
https://www.ibm.com/support/knowledgece ... _host.html
BrianL
Version: 9.5.2 10.1 10.2 PA2
Post by BrianL » Fri May 25, 2018 3:06 pm
What is the UseSSL setting in the tm1s.cfg? If it's set to T you'll need to use httpS instead of http.
