TM1 instance stuck on restart on StatsBy... cub files
vladino
Excel Version: Excel 2013
Post by vladino » Wed May 02, 2018 7:54 pm
Hi guys,
we are experiencing weird behavior when trying to restart a TM1 instance.
It is stuck on "TM1ServerImpl::Destroy: Commit changes" and it never ends. So the only way is to kill the process itself...
In the Data folder I can see that all "StatsBy..." cubes are being overwritten (there are *.cub$ files).
How to resolve this please? Appreciate any help!
BR
Vladino
macsir
Version: PAL 2.0.8
Re: TM1 instance stuck on restart on StatsBy... cub files
Post by macsir » Wed May 02, 2018 9:13 pm
Never heard about that before. Did you manually save data before restarting?
vladino
Post by vladino » Wed May 02, 2018 9:58 pm
Sure, I have written a process that runs CubeSaveData for all cubes and before restarting the instance I'm also running SaveDataAll.
macsir
Version: PAL 2.0.8
Post by macsir » Thu May 03, 2018 4:46 am
I think there is some conflicting between the two functions. If you use savedataall, it is unnecessary to use CubeSaveData to save all cubes.
vladino
Post by vladino » Thu May 03, 2018 7:02 am
I don't think that this is the reason - sometimes it is restarted successfully, but most of the times it is stuck.
Btw. when I don't run CubeSaveData and kill the process then all data changes for cubes that aren't logged are gone... This is the reason why I'm running both CubeSaveData and SaveDataAll.
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Post by gtonkin » Thu May 03, 2018 7:18 am
Are your saves in Epilog?-had issues previously with these in Prolog.
vladino
Post by vladino » Fri May 04, 2018 12:36 pm
Both CubeSaveData and SaveDataAll are in Prolog... I will give it a try and let you know guys, thanks!
vladino
Post by vladino » Fri May 04, 2018 9:23 pm
Hmm, that's interesting... It seems that it works! :)
Let's wait for a while if the issue is resolved. Thank you sir!
vladino
Post by vladino » Sat May 05, 2018 7:50 pm
Bad news here guys... :-/
Still sometimes hangs on "Commit changes", }StatsBy... cubes hangs in "cub$" state and the only way is to kill the process manually.
Any other suggestions?
