DIMENSIONELEMENTCOMPONENTADD - Not working as expected - Please advise
Ashleigh W
Version: TM1 Perspectives 10
Excel Version: Excel 2016
Post by Ashleigh W » Tue Apr 10, 2018 10:50 am
Hi everyone,
Below is the sample syntax I am trying to add element to Parent called 'Total Entity'.
DIMENSIONELEMENTINSERT('dimName','', xle , 'N' );
DIMENSIONELEMENTCOMPONENTADD( 'dimName', 'Total Entity', xle, 1);
Someone time the result shows elements added under 'Total Entity' as child (which I want) but some time goes outside 'Total Entity' meaning does not get added as child. What could be the reason? What I'm I doing wrong?
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Re: DIMENSIONELEMENTCOMPONENTADD - Not working as expected - Please advise
Post by gtonkin » Tue Apr 10, 2018 10:52 am
Check your dimension sort order. Try set to Hierarchy, by Name if not set already.
Ashleigh W
Post by Ashleigh W » Tue Apr 10, 2018 10:58 am
Not sure what that means. Do we set it from edit dimension structure? or via code? This is the code that will add elements going forward
Version: PAL 2.0.3
Post by gtonkin » Tue Apr 10, 2018 11:02 am
Right click your dimension, click Set Elements Order then Automatic and Hierarchy. You can use TI to set this too, to set to Hierarchy and name, but try the right-click method first.
Post by tomok » Tue Apr 10, 2018 11:04 am
It's in the }DimensionProperties cube but you can also set it via TI. Please consult the TI functions help.
Ashleigh W
Post by Ashleigh W » Tue Apr 10, 2018 11:24 am
Set to sort manually by Name.
Still same issue. example below, 903 and 904 are not rolling up to Total Entity.
is below code incorrect?
+Total Entity
--900
--901
--902
903
904
Version: PAL 2.0.3
Post by gtonkin » Tue Apr 10, 2018 11:27 am
Currently set or was set? Did you change to automatic by hierarchy?
If you select element 903, can you roll it up to check what its parent is?
Ashleigh W
Post by Ashleigh W » Tue Apr 10, 2018 11:34 am
Initially it was not set to auto sort by Hierarchy. I have done that now.
Now after auto sort set, I deleted all elements and try adding again using code and it seems to be working. What was I doing wrong?
Also please clarify what does element weight parameter mean here in DIMENSIONELEMENTCOMPONENTADD
Version: PAL 2.0.3
Post by gtonkin » Tue Apr 10, 2018 11:44 am
Generally when you create a hierarchy with levels, you would set sort order to Hierarchy so that it represents as a tree structure.
This however depends on your goal as you may choose manual and order elements as you want. No right answer here.
Would refer you to the manuals/online help with element weighting. But loosely, this is the multiplier used when aggregating child elements up the hierarchy.
Ashleigh W
Post by Ashleigh W » Tue Apr 10, 2018 12:03 pm
ok. Thanks for your help!
Ashleigh W
Post by Ashleigh W » Tue Apr 10, 2018 12:18 pm
Do I need to execute this code from MetaData tab or Prolog itself is fine?
Version: PAL 2.0.8
Post by Wim Gielis » Tue Apr 10, 2018 12:39 pm
If you have a data source, like a relational table or flat file, then probably in the Metadata tab.
If it's elements that you insert as a one-off and not through a data source, it would go in the Prolog tab.
http://www.wimgielis.com ==> 112 TM1 articles and a lot of custom code
Newest blog article: Selecting elements in the Subset Editor quickly
Post by tomok » Tue Apr 10, 2018 1:24 pm
You didn't do anything "wrong", it's just that the information you were giving us was "fake news". Sorry, couldn't help it. Those DIMENSIONSORT functions have absolutely NOTHING to do with how children roll up to a parent. All they control is the order of how the elements appear in a dimension. Absent a default subset, if you double-click on a dimension and open the subset editor you are going to see the elements in the order they appear in a dimension, sometimes with consolidated nodes mixed in with leaf nodes. It appears that some leaves may not appear to be a children of their parents based on this listing. However, if you were to expand the parents you would see that they are there. This was likely the case. I have never, ever seen a case where a proper use of DIMENSIONELEMENTCOMPONENTADD did not add a child to a parent and your syntax looked correct.
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC » Tue Apr 10, 2018 1:47 pm
This seems slightly harsh given fake news is the deliberate attempt to fool the gullible/stupid.
Post by tomok » Tue Apr 10, 2018 4:48 pm
You do realize it was humor, right?
Mark RMBC
Version: 10.1.1
Post by Mark RMBC » Wed Apr 11, 2018 9:21 am
I obviously should have added a smiley after my comment! :D
Ashleigh W
Post by Ashleigh W » Fri Jul 13, 2018 11:47 am
:) :thumbsup:
