User does not have permission to browse the selected server
LeeTaylor1979
OLAP Product: IBM Cognos TM1
Post by LeeTaylor1979 » Fri Jun 24, 2016 9:23 am
Up until Friday all was fine, Monday morning how ever my users are getting the following message when trying to access TM1 via Perspectives and Architect on one instance only.
User does not have permission to browse the selected server.
Although receiving this message it does actually connect the user but they cannot see anything.
Their access is fine through TM1 web and TM1 Application (Contributor)
We have 4 instances of TM1 and this only occurs on one the other 3 there is not issue.
There has been no change to the group security or any other security.
I have tried bouncing the BI server (as we use CAM) and TM1 server but the issue remains.
Any idea what may have happened here ?
Thanks in advance.
Version of TM1 being used is 10.2.2
qml
Version: 2.0.6 and all previous
Excel Version: 2007 - 2016
Re: User does not have permission to browse the selected server
Post by qml » Fri Jun 24, 2016 9:46 am
Check if any of the circumstances mentioned in this technote apply to you.
Kamil Arendt
LeeTaylor1979
Post by LeeTaylor1979 » Fri Jun 24, 2016 10:01 am
Thanks qml,
Versions are the same and admin host has been checked on all users these are also fine.
CathyBoots
OLAP Product: Tm1
Excel Version: Prof Plus 2013
Post by CathyBoots » Wed Oct 11, 2017 8:05 am
Did you get a resolution to this issue? I've got the same error.
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin » Wed Oct 11, 2017 9:53 am
Grasping at straws but do you have another TM1 service on this host with the same port number?
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Thu Oct 12, 2017 1:34 am
Have you checked the "Access to Server Explorer" in Capability Assignments in Perspectives? If it is deny then user will get this msg.
