Active Forms with Filters
Paul-TM1
Post by Paul-TM1 » Tue Sep 10, 2019 9:25 pm
I am looking for an idea on how to filter in an Active form.
As shown in the picture, I want to allow users to pick the highest level of the project from a drop down and only the leaf level elements of the chosen project must be available.
Can someone please help me?
Paul.
Version: PAL 2.0.8
Re: Active Forms with Filters
Post by Wim Gielis » Tue Sep 10, 2019 9:32 pm
Use an MDX statement to return these children, based on the value of a cell (like a SUBNM).
You can fully customize this. In the MDX argument of the TM1RPTROW function, refer to the (hidden) cell that contains the MDX expression.
That MDX would be a string where a cell reference to the project choice is made and hence, used in the expression.
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 model with AutoHotKey as a service or application
Post by tomok » Tue Sep 10, 2019 10:39 pm
This MDX statement:
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[YourDimension].["&A1&"]}, ALL, RECURSIVE )},0)}
placed in your TM1RPTROW formula will filter to all the leaf elements of the parent contained in cell A1. In A1 you could put a SUBNM formula or a data validation Excel drop down formula.
Version: PAL 2.0.8
Post by Wim Gielis » Wed Sep 11, 2019 12:04 am
As there is TM1DRILLDOWNMEMBER, DRILLDOWNLEVEL, ... and also to for the arguments ALL and RECURSIVE,
I tend to use Descendants:
="TM1FILTERBYLEVEL( DESCENDANTS( {[YourDimension].[" & A1 & "]}), 0)"
Paul-TM1
Post by Paul-TM1 » Wed Sep 11, 2019 6:07 pm
Thanks Wim and Tomok.
I need some more help.
This is the code I see and where should I add?
=TM1RPTROW($B$9,"ABC:Projects","",'{AR}01'!$B$16:$B$17,"Number And Name",0)
I tried to add it towards the end, but it's erroring out. From the syntax, I placed it in the MDXStatement and in SubsetElements and failed in both attempts.
Code below is what I replaced with.
"E13" is the drop down list that has the Projects.
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[YourDimension].["&E13&"]}, ALL, RECURSIVE )},0)}
Syntax:
TM1RptRow(ReportView, Dimension, Subset, SubsetElements, Alias, ExpandAbove,MDXStatement, Indentations, ConsolidationDrilling)
Paul.
Post by tomok » Wed Sep 11, 2019 6:21 pm
For the TM1RPTROW formula you provide either a subset OR an MDX statement parameter. This is an MDX parameter. Use the function editor in Excel to help you get the syntax correct.
