Copy the location of an Excel file to the clipboard
Version: PAL 2.0.8
Post by Wim Gielis » Fri Oct 18, 2013 5:17 pm
Hello all
This is more of an Excel topic, but I wanted to share this piece of code with you.
I use it to store the path and name of an Excel file in the clipboard, when I need to email the file.
The code is part of my personal macro workbook and it's executed from the QAT.
If the file has not been saved yet, no location exists, and the code will ask you to save the file first.
Note that you must add a reference to the "Microsoft Form 2.0 Object Library".
If anyone knows a simple way to the clipboard without needing this reference, let me know.
Can you please try this code on your environment, particularly network lcoations, ...
Public Sub FilenameForOutlook()
' Wim Gielis
' October 2013
    Dim sFileName As String
    Application.ScreenUpdating = False
    With ActiveWorkbook
        If (Len(.Path) > 0) And (Len(Dir(.Path, vbDirectory)) > 0) Then
            ''''' FILE WAS ALREADY SAVED '''''
            'save the file
            If Not .Saved Then
                Application.DisplayAlerts = False
                Application.EnableEvents = False
                On Error Resume Next
                .Save
                On Error GoTo 0
                Application.DisplayAlerts = True
                Application.EnableEvents = True
            End If
            'get the fullname
            sFileName = .FullName
        Else
            ''''' WFILE WAS NOT ALREADY SAVED '''''
            With Application.FileDialog(msoFileDialogSaveAs)
                'a file was picked
                If .Show Then
                    'save the file
                    .Execute
                    On Error GoTo 0
                    'get the fullname
                    sFileName = ActiveWorkbook.FullName
                End If
            End With
        End If
    End With
    'store in the clipboard
    If Len(sFileName) Then
        If Len(Dir(sFileName)) Then
            With New DataObject
                .SetText sFileName
                .PutInClipboard
            End With
        End If
    End If
End Sub
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 model with AutoHotKey as a service or application
mauriciosaucedo
Version: 9.5.2
Re: Copy the location of an Excel file to the clipboard
Post by mauriciosaucedo » Thu Mar 06, 2014 1:00 am
Hi Wim
Another option is to add the Document Location command to the quick access toolbar, that way you don't need any libraries.
I use Excel 2007 but I think its also available in 2010
