Page 1 of 3
Another TM1 TOP
Posted: Thu Sep 27, 2012 11:08 am
by Ricky Marwan
Monitor client(s) activities and Message Log at the same time.
TM1 Server Monitor
tm1 server monitor.jpg (110.93 KiB) Viewed 16407 times
Compatible TM1 Version(s):
TM1 9.5.2
TM1 10.1
Features:
1. Log activities
2. Open log directly from app
3. Broadcast message
4. Cancel Thread
5. Disconnect Client
6. Send Message
7. Auto connect
8. Monitor Message Log
Requirements:
.Net Framework 4
How to Setup:
TM1 Server Monitor - User Guide.pdf
User Guide
(430.96 KiB) Downloaded 1163 times
TM1 Server Monitor 1.1.rar
(331.47 KiB) Downloaded 732 times
TM1 Server Monitor 1.1.zip
TM1 Server Monitor 1.1 (ZIP)
(746.05 KiB) Downloaded 906 times
Re: Another TM1 TOP
Posted: Thu Sep 27, 2012 2:26 pm
by JDLove
Hi Ricky,
Installed ok
W7
TM1 10.1
Thanks for that !
Re: Another TM1 TOP
Posted: Fri Sep 28, 2012 5:25 am
by Olivier
Nice and easy to get up and running, tested with 9.4MR1 FP3.
Re: Another TM1 TOP
Posted: Mon Oct 01, 2012 12:17 am
by Harvey
Nice work, Ricky! This looks really nice.
Re: Another TM1 TOP
Posted: Mon Oct 01, 2012 11:16 am
by Ricky Marwan
Updated Version 1.0.1
- View log in Excel for easy analysis, filters etc.
- Allow to refresh connection when unavailable without closing tab
Re: Another TM1 TOP
Posted: Fri Oct 05, 2012 10:57 am
by Ricky Marwan
Updated Version 1.0.2
- Auto connect to server(s) at startup (app)
- Reconnect button shown if connection unavailable
Re: Another TM1 TOP
Posted: Wed Oct 10, 2012 4:39 am
by Ricky Marwan
Updated Version 1.1
- Monitor TM1 Server Message Log
Re: Another TM1 TOP
Posted: Wed Nov 07, 2012 4:11 pm
by iansdigby
Probably the best thing since sliced bread.
Thank you.
Re: Another TM1 TOP
Posted: Tue Jan 29, 2013 1:41 pm
by Steve Vincent
for people who can't expand RAR files i have just updated the original post with a ZIP version too
Re: Another TM1 TOP
Posted: Fri Feb 15, 2013 3:35 pm
by sleepyEDB
A most excellent tool...thank you very much!
sleepy
Re: Another TM1 TOP
Posted: Wed Mar 06, 2013 8:54 am
by Steve Vincent
I'm having an issue where the program crashes on start up. I suspect it's a bug related to the number of services i asked it to load on start up (4, i think) but i don't know where its storing the start up config. Is there any way to edit that manually to get the program working again?
Re: Another TM1 TOP
Posted: Thu Mar 07, 2013 2:58 am
by Ricky Marwan
Steve,
Thanks for the feedback, will fix the bug soon.
the settings file is located in (Win XP):
C:\Documents and Settings\<user>\Application Data\TM1 Server Monitor
you may delete the file.
cheers
Re: Another TM1 TOP
Posted: Thu Mar 07, 2013 1:07 pm
by Steve Vincent
Superb, thank you. I can confirm i had 4 services listed, i just altered the flag of one to "<AutoConnect>false</AutoConnect>" and it's loaded just fine. It also autoloaded the service i flagged as false, which may point you to where the bug is :)
Re: Another TM1 TOP
Posted: Thu Mar 07, 2013 2:00 pm
by Paul Segal
I've been meaning to post about this - I've had the same problem, just to confirm what Steve is saying.
Re: Another TM1 TOP
Posted: Wed Mar 13, 2013 9:23 pm
by show75
I need your help i use tm 9 and tm1top but i can not do any dthing when this massege come "object duplicate" and i can not kill or stop this thing so i need your help please
Re: Another TM1 TOP
Posted: Thu Mar 14, 2013 2:28 am
by Ricky Marwan
show75,
are you reporting bug? if so, provide me a screenshot of the error please.
check this out http://www.tm1forum.com/viewtopic.php?p=9378
Re: Another TM1 TOP
Posted: Fri Mar 15, 2013 3:38 pm
by ppos
Hello Ricky,
Your tool is really great but as I assume there is no way to "verify admin access" if TM1 server uses CAM authentication. Are you planning to add such functionality?
Kindes regards
Pawel
Re: Another TM1 TOP
Posted: Sat Mar 16, 2013 11:28 am
by Ricky Marwan
Hi Pawel,
I plan to have all security type, but currently i don't have TM1 server configured with CAM security.
I can add function to verify CAM easily, but for sure i need to test it myself before releasing the tool.
If you keen to help, i can give you the tool compiled with CAM for you to test, email me if you interested.
Re: Another TM1 TOP
Posted: Wed Mar 20, 2013 8:21 am
by Ricky Marwan
New Version, build using Qt no .Net Framework required
If TM1 installed other than C:\Program Files\Cognos\TM1 add your TM1 bin directory to PATH environment variables or copy executable and related dlls into TM1 bin folder
download here:
http://sdrv.ms/16KJzuI
Note:
For those using CAM, the program won't check whether supplied user has ADMIN group assigned.
Re: Another TM1 TOP
Posted: Wed Mar 20, 2013 8:49 am
by Paul Segal
Excellent job Ricky - this looks and feels really good. I'll give it a soak test on four servers for a day or two and let you know how it does.
