CellIncrementN and BatchUpdate Mode
- paulsimon
- Version: PA 2.0.5
I have just found an issue whereby CellIncrementN when you are in BatchUpdate Mode works like CellPutN
This is present in at least versions 10.2 IF1 and 10.2 FP1 IF1.
This has been reported to IBM.
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: CellIncrementN and BatchUpdate Mode
I'm not sure that I would have accepted that as a bug if I had been IBM, given that the stated behaviour of BatchUpdateMode is that values written to cells are not available to the TI until the transaction is committed, so you would always be incrementing the value that was there at the start of the transaction.
Is that in fact what is happening? If the TI starts with a value in the cell, is the value at the end the last value applied or is it the sum of the original value and the last value applied?
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
I just wanted to report this bug to the forum when I saw Paul had already done so, I ran into this just today.
Why I would think this is a bug is that batch update mode works fine with the old logic:
vOldValue = CellGetN(...
CellPutN(Value + vOldValue , ...
I would expect the CellIncrementN should do the same.
- Version: [2.x ...] 11.4.x / PAL 2.0.6
- Excel Version: Excel 2010-2013
I thought it is more or less the TI version of the deferred update in the GUI, a kind of ancestor of sandboxing giving a private version of a cube structure without consolidations & rules. N-element values should be accessible at that time.
- OLAP Product: IBM Planning Analytics
- Version: 2.0
Sorry for performing necromancy..
Does anyone have update on this? Just encountered exactly the same issue as Paul on PA 2.0.
BR,
Simon
BR,
Simon
Why are you using BatchUpdate? This is something I haven't used since ParallelInteraction was introduced. I really don't see a need for it in PA. If you think I'm wrong, convince me otherwise.ultrakocka wrote: ↑Wed Aug 21, 2019 11:11 amSorry for performing necromancy..
BR,
Simon
- Version: 2.0
How else can you move large-ish amount of data between cubes/within cube in reasonable time? I'm asking because I sincerely have no idea. Switching on batch update just gives me much faster processing time.
Cube to cube processing operations are typically very fast (say >40K cells/second).
Where it is slower than this the reasons are usually
1. dynamic subsets
2. where source & target are contained in the same cube slice
3. data input triggering heavy feeding
Solve
1. by never using dynamic subsets in data processing
2. use an intermediate export/import in processing (it sounds counter-intuitive but often it is many times faster to export to a CSV and then read the CSV in a separate process rather than all in a single step. Or rather than using a file use a background staging cube, this is faster.)
3. Using RuleLoadFromFile detach rule, load data, reattach rule. Especially now with MTQ.Feeders=T this can be much faster.
And there's always the strategy of splitting data loads into multiple chunks and running in parallel. In the latest versions of PA with the RunProcess function or in earlier versions with TM1RunTI.exe. You can often get a near linear improvemernt in throughput by scaling over multiple cores rather than using a single core. It does depend in the ratio between commit time and processing time which depends on dimension index order vs the dimension used for each slice (complicated topic to explain). Of course this depends on having the correct licensing and the CPUs available to do it.
1. dynamic subsets
Solve
- Version: 2.0
Hi Lotsaram,
Definitely not getting the ~40k cells/s processing speed - will try to implement point 3) instead of batchUpdate (of which purpose is the same - stop processing rules and feeders while running the process).
I have no experience using RunProcess, but definitely will give it a shot when there is some free time on my hands.
Thanks a lot for the suggestions!
