Hello all,
Used the following sequence :
1- Published a TM1 cube to 10.2 BI.
2- On knowing that named levels were missing, I entered the values for named hierarchies in }hiererchyproperties control cube
3- Ran the RefreshMdxHierarchy(''); TI process.
After these steps, I launched the BI Report studio to see the changes but the named levels didn't show up.
I even recreated the package and published it but it didnt work
Can someone suggest where am I going wrong here? I also read that the server needs to be restarted but running the TI in step 3 above should also work
request your advise.
I tried looking into other posts but was not successful at finding one
Gbehel
Named Levels not showing up!!
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Named Levels not showing up!!
Two things:gbehel wrote:Hello all,
Gbehel
1. did you run RefreshMdxHierarchy('') or RefreshMdxHierarchy('dimname')? You have to run the command per affected dimension.
2. sometimes the level names have a hard time coming through (I assume due to persistent caching) - sometimes you need to either flush your browser cache, republish the package or even restart the BI server for this...
Michel
- qml
- Excel Version: 2007 - 2016
In theory, either syntax should work fine with the first one refreshing all dimensions. I personally have never used it like that, but it should work.Michel Zijlema wrote:1. did you run RefreshMdxHierarchy('') or RefreshMdxHierarchy('dimname')? You have to run the command per affected dimension.
I think Michel's suggestion of restarting the BI services is probably the most sound. Before you do that you can try and flush the metadata cache (there is an option for that somewhere deep in the Cognos Connection admin section).
Kamil Arendt
- Michel Zijlema
You learn something every day... I missed the 'optional' part in the function documentation.qml wrote:In theory, either syntax should work fine with the first one refreshing all dimensions.Michel Zijlema wrote:1. did you run RefreshMdxHierarchy('') or RefreshMdxHierarchy('dimname')? You have to run the command per affected dimension.
Michel
- OLAP Product: TM1, Cognos EP, Contributor
- Excel Version: 2013
Thanks Michael and Qml : Yes in theory both the options should. I tried doing it per dimension also by specifying the Dimension Name. However it didnt work. I finally restrated the TM1 services and BI server. It worked fine from that point onwards.qml wrote:In theory, either syntax should work fine with the first one refreshing all dimensions. I personally have never used it like that, but it should work.Michel Zijlema wrote:1. did you run RefreshMdxHierarchy('') or RefreshMdxHierarchy('dimname')? You have to run the command per affected dimension.
Thanks for your help
Gbehel
