Ran into a brick wall here...
MDX below is not happy:
{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [Customer] )}, 0)},[Customer Active Status].([Period].([System Info].( StrToMember([System Parameters].[Current Reporting Period]) ) ,[Active Status Measure].[Value])=0))}
What I am trying to do here is to filter out customer dim based on Customer Active Status cube value of 0... while its straightforward, the culprit is that I am trying to replace [Period].[Element] qualifier with the current reporting period string from the System Info cube (dim [Period]. [element from System info cube] ) ... .
this part here: [Customer Active Status].([Period].([System Info].( StrToMember([System Parameters].[Current Reporting Period]) )
Error im getting:
syntax error at or near: '[System Info].(StrMember( ......
I tried to pull that period string in the actual period dim with
{TM1FILTERBYPATTERN( {TM1SUBSETALL( [Period] )}, [System Info].(StrToMember("[System Parameters].[Current Reporting Period]"),[System Measures].[String]))}
and worked happily. . .
Please suggest. I think I have been looking at it for too long now
