There is a bug in 64-bit TM1 10.1.1 Operations Console installation in Windows enviornment.
The TM1 Operations Console will not work if TM1 Admin Server is using non-default ports. According to IBM support the fix of this bug will likely not be available as a patch for version 10.1.1, but most likely it will be fixed in version TM1 10.2. To-date there is no information when version 10.2 will be released.
Solution/Workaround:The workaround to this issue is to change the Port settings of TM1 Admin Server and change it use default ports.
TM1 Operations Console Installation issue
- rkaif
- Version: 9.1 or later
Cheers!
Rizwan Kaif
Rizwan Kaif
