TM1 Web Picklist Performance
Posted: Fri May 04, 2012 8:34 am
All,
On 9.5.2 (patched up to all but the most recent pack).
I had a websheet that contained a standard excel list (which was populated by formulas in a hidden column) that allowed users to select only valid Products based on a Brand that they were using (defined within a cell elsewhere.)
This list could on occasion have quite a few product but not monumental amounts (around 300 or so at tops), this had always worked in TM1 Web with reasonable performance... until a few weeks ago.
A few weeks ago the performance of the websheet in question became completely abysmal, all other websheets carried on as expected.
I obviously rebuilt the websheet from scratch in a few guises:
1/ Basically the same - Using an Excel List --- Awful Performance Still - Great in Excel
2/ Identical to 1 but using a subset picklist that changed via a rule based on what brand the user was using --- Awful Performance for TM1 Web - Great in Excel
Option 3 works at lighting fast speeds, I have a process that creates dummy dimensions for every single brand by a series of while loops, the websheet then just looks at said dummy dimension with a subnm. I don't mind using option 3 as it is actually sort of prettier for the user since they get to see the full hierarchy etc for their brand.
The question is more over has anyone else noticed a change in performance when using lists or picklist in tm1web lately. All I can think that has changed is a patch to Excel 2007 on the TM1 Server around the same time.
Any ideas would be appreciated, its not urgent but just my curiosity really.
Thanks in advance.
Thanks in advance.
