same cube CellGetN for a IF argument and CellPutN
BigG
OLAP Product: IBMPA
Version: PA 2.0 Cloud
Post by BigG »
Hi there,
I have a 'detailed cube' with a string element in measure dimension - REGION. Within the same cube and measure dimension I have numeric VALUE.
A global cube holds region % rates. Region is a dimension for this global cube.
A TI Process transforms the VALUE into further detail by multiplying by each regions % rates. To get the correct % we need to refer to what REGION from string in detailed cube, then get the related % from global cube.
I havent fully tested this but Is the best way to do this by (not true syntax below but basic logic)
IF(cellgets(detailed cube)) = 'a region';
CellPutN(target cube*% a region)
ELSEIF(cellgets(detailed cube)) = 'another  region';
CellPutN(target cube* another region)
GG
Re: same cube CellGetN for a IF argument and CellPutN
There is no need to do a list of IF and ELSEIF's as long as the value in the REGION element of the measures dimension corresponds EXACTLY to one of the elements in the REGION dimesion of the global cube. I don't know where the value you are multiplying by the rate is coming from since I don't know the source in your TI process. Assuming you are using a view from the detail cube which pulls VALUE, and your "Target" cube has a measures dimension with a numeric element called "VALUE", you can just do this:
Region = CellGets('detailed',Dim1, Dim2,..DimX,'REGION');
Rate = CellGetN('Global',Dim1, Dim2,..DimX,Region);
NewValue = VALUE * Rate;
CellPutN(NewValue,'Target',Dim1,Dim2,DimX..,'VALUE')
BigG
OLAP Product: IBMPA
Post by BigG »
thanks, this all makes sense. cheers for response
GG
