Selecting whole text in TI tab
jstrygner
Version: 9.5.2 FP3
Post by jstrygner » Wed Nov 10, 2010 10:44 am
By accident I found a way to select whole text in a TI tab (there is no Ctrl+A, at least in my 9.5.1).
You press 'Tab' key that changes the focus from text field with TI code to 'Goto Line...' button.
Pressing 'Tab' once more selects whole text in active TI tab.
Regards.
Version: 10.2.2., PAW
Re: Selecting whole text in TI tab
Post by Steve Rowe » Sat Nov 27, 2010 1:37 am
Nice tip, used that many times since I saw your post. Cheers
dilip
Version: 9.4
Post by dilip » Mon Jul 20, 2015 8:07 pm
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Post by Wim Gielis » Wed Jul 22, 2015 8:29 am
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
dilip
Version: 9.4
Post by dilip » Wed Jul 22, 2015 8:39 am
Very nice..Thanks for sharing other shortcuts.
hiraniha
Version: 10.2.2 FP1
Post by hiraniha » Wed Oct 07, 2015 3:52 am
When does this help you?
It also selects the two special lines, which means you can only copy an paste it to another editor, but when you copy it back you have to then select the old fashioned way otherwise you can't paste back, am I missing some advantage of this?
btw, another keyboard combination is <ctrl>-<i>, which will put a tab character into the code, I don't use it as I prefer a couple of spaces.
regards
hiraniha
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Post by jim wood » Wed Oct 07, 2015 12:57 pm
hiraniha wrote:When does this help you?
When deploying code without bringing services down? Simply copying code from one to another....
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
hiraniha
Version: 10.2.2 FP1
Post by hiraniha » Wed Oct 07, 2015 9:01 pm
Hi Jim,
That's my point, it will select the generated lines in both source and target, which means you have to revert to a manual method, like Ctrl/Shift/End.
I was just wondering if there was something I was missing that meant selecting everything helped.
regards
hiraniha
Version: PAL 2.0.6
Post by Wim Gielis » Thu Oct 08, 2015 7:56 am
hiraniha,
You're not missing something here, there just is no other way to do efficient copy/paste of code in TI.
jim wood
Version: TM1 10.2.2
Post by jim wood » Thu Oct 08, 2015 12:14 pm
I can't see the issue. When you paste you just have to delete the top few lines. No exactly a big deal, especially compared to selecting manually the whole tab of a TI that has hundreds of lines of code. How does that make this unhelpful?
hiraniha
Version: 10.2.2 FP1
Post by hiraniha » Thu Oct 08, 2015 9:13 pm
Jim,
I am stilling missing the trick, so I see it helps when you are pasting into a new TI tab, that is blank. Then you delete the two generated lines. Debatable as to whether the good old fashioned crtl/shift/end from the first line of the code isn't actually quicker.
If I am migrating a change to an existing TI, I copy the entire tab using the described way of selecting everything, then what is the trick when selecting everything on the target, as this method selects the generated lines so I can't delete or paste it without an error. If I try to delete the code comes back, and if I paste it it keep the original code and the new code, which is worse.
I thought this was trying to suggest a trick way of still pasting the code? Perhaps not, in that case a crtl/shift/end from the first line of the code does the job much better.
regards
hiraniha
jim wood
Version: TM1 10.2.2
Post by jim wood » Mon Oct 12, 2015 2:06 pm
The reply was based on you saying when does this help you. You didn't compare it to any other way of doing it. I'm not doubting there are other ways that you may prefer but dismiss this as you did is the reason why you got the replies you did. You need to make sure that:
a) You're not so dismissive
b) If you do have a valid reason for a) you back up within your initial reply, not 4 posts later.
hiraniha
Version: 10.2.2 FP1
Post by hiraniha » Mon Oct 12, 2015 10:45 pm
Jim,
Not sure if I have offended you. Apologies If I have.
All I was trying to determine was if I was missing something on how to use this as I couldn't get it to paste properly and deal with the generated statements.
I was hoping that someone was going to suggest a little trick to handle that
regards
hiraniha
Version: PAL 2.0.6
Post by Wim Gielis » Tue Oct 13, 2015 7:42 am
hiraniha, did you see my post above ? I wrote that you were not missing something and there isn't (at least to my knowledge) any neat trick out there.
I usually copy/paste to Notepad++ (all code at once, with Tab-Tab), then I edit the code there, I go to the top of the file in Notepad++ with Ctrl-Home, I hit Ctrl-L a couple of times, I do Ctrl-A, Ctrl-C and then I Ctrl-V in the TI tab (where I first select the text after the generated statements).
