Zero Out of Cube with String value as picklist
- Excel Version: 2003
I'd just like to check with you guys, when you zero out a cube with a mix of string & numeric elements and the string containing a picklist. Shouldn't the picklist be cleared of any content during zero out? I just want to check is this is normal or not in TM1 since for none picklist string elements it does clear the contents of the field.
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
Re: Zero Out of Cube with String value as picklist
are you talking about clearing out the picklist selection items?
This would not clear since the picklist is on the dimension member and not related to the cube.
or clearing out the cell value which is chosen from the picklist?
This should be cleared and I have not had an issue with this.
Ankur Jain
