The data in our cubes is reloaded on a nightly basis and it is not cached in memory, due to which there is a wait time for the first person who logs on to the server and opens any cube. It has been recommended that after the nightly data load is run, the data should be precalculated on a nightly basis. How can we achieve this? Is there a Ti function which can be used to do this job? Please let me know. Your responses will be highly appreciated. Thanks!!
Rfed
Bringing Cubes in memory
Re: Bringing Cubes in memory
ViewConstruct(cubename, viewname)
From our original tests, admittedly on a much earlier version, a browsing a view prebuilt with ViewConstruct wasn't _quite_ instant, compared to a view which had already been browsed, but it was a lot quicker with than without.
- Version: 9.4.1 9.5.1
Thanks for your reply.
So, if I want to refresh multiple cubes, will I need to create a TI consisting of this function written for all the cubes with a default view?
I will need to run it as a chore after the data is done loading every night. Please correct me if I am wrong.
Please let me know.
RFed
Please let me know.
RFed
- Steve Rowe
Hi rfed,
That's correct.
Test carefully though you need to make sure your hardware can handle all the cube in the server being precalculate. If you are on 64 bit that shouldn't be a problem.
That's correct.
