Hi TM1 Gurus
I have a cube view like the foll
______________________________________________________________________________
Year Dim(To select years from 2008-2010)
------------EAD(Current)----EAD(Forecast)
q1
---Jan
---Feb
---Mar
q2
---Apr
---May
---Jun
q3
---Jul
---Aug
---Sep
q4
---Oct
---Nov
---Dec
We have values for Ead(Current) and for EAD (forecast)they want to use previous month data. For jan 2010 u should have dec 2009 data(of Ead current), for feb 2010 u should have jan 2010 data(of Ead Current)
How can i do it with less rules, like i dont want to write rule for every month.Please suggest me the best way to do it.
Daya
Previous month
- rkaif
- Version: 9.1 or later
Re: Previous month
The following post will help you to do what you need:
http://forums.olapforums.com/viewtopic. ... 08&start=0
Cheers!
Rizwan Kaif
Rizwan Kaif
- Version: 9.5.1
- Excel Version: 2003
Re: Previous month
My Problem here is....forecast is just previous month data, we dont need to do any calculations. how best we can solve this.
Please help...i am new to TM1
- Alan Kirk
Re: Previous month
To be honest if (a) it's purely the previous month's values tha you need and (b) the previous month's values are locked down after end of month, I wouldn't even bother with rules; I'd just use TI to copy last month's EAD(Current) into this month's EAD(Forecast) after the actuals month has been closed. There's no point wearing both feeders and the calculation overhead if the values will be fixed anyway.daya007 wrote:My Problem here is....forecast is just previous month data, we dont need to do any calculations. how best we can solve this.
You could use a lookup dimension to get the elements using the DimIx function suggested in the thread that Rizwan pointed you to, but it would be just as easy to hard code an If block into the TI to look up the previous month (and previous year, if the current month is January). You could use parameters in the TI process to specify the month and year that you're copying, or calculate those from the current date.
I can go into more detail if you want, but it's academic unless this approach would work for you.
- Version: 9.5.1
Re: Previous month
Hi thank you very much for the reply..I really appreciate the way u explained. I am a beginner and am not able to decode ur reply.
It will be very helpful if u could reply me in detail.
Thank you again
daya
Thank you again
daya
