Can anyone tel me if we can create cubes using TM1 Web interface, If we can pls tel me - how to create??
Jithin
Cube creation inTM1 Web.
Re: Cube creation inTM1 Web.
Don't think so. To create cubes manually (the usual approach) you should use Perspectives or Architect. You can write a TI to create a cube but to do that you'll need...
Happy to be contradicted though.
- rkaif
- Version: 9.1 or later
You can write a TI process which 'creates' a specific cube.
Then from the TM1Web you can run that process which will create the cube for you.
Otherwise there is not such option in TM1Web itself which allows you to created cubes on the fly. TM1Web is more for the end users so that they can view the existing objects.
Cheers!
Rizwan Kaif
Rizwan Kaif
Thanks a lot for the valuable information
Jithin
Jithin
