Issue When Changing Aggregation Type
Version: TM1 10.2.2
Post by jim wood » Fri Apr 30, 2010 12:34 pm
Guys,
If you are in a pivot and you have display results switched on, do not change the aggregation type before the result comes back. If you do it will not remember the change. It defaults back to the previous a type,
Jim.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
