I have a requirement to import cubes which contain control objects(to get information of views) into FM created in TM1.
After creating TM1 datasource we are able to import only data cubes.
Should I need to perform some operation in TM1 architect to make it visible in FM datasource.
Thanks & Regards,
Naveen
Import data from Control Cubes into Framework Manager
- Version: 9.4
Re: Import data from Control Cubes into Framework Manager
I found no way to let control cubes show up in FM. A workaround would be to create a new normal cube with the same dimensions that build your control cube. Not nice of course. For view stats you would need to populate it with rules probably.
Has anyone found a way to import control objects into Framework manager?
Paul.
Paul.
