Issue: TM1 Drill through SQL does not allow me to write "left joins" to a relational database. (there are other inconsistencies but left join is easiest to use as an example) But TM1 does allow me to Join in the where clause.
Example : Per the below both queries work in SSMS. But only the first one works as a drill through in TM1. (with very limited error log "Unable to fetch data")
Request: Can anyone advise why this is happening and if I can fix it? (as I would like to use the second one to keep consistent coding methodology across platforms) Is there documentation I can follow (its not only "left joins" there are other inconsistencies that are hard to diagnose with TM1's standard error messages)
''#########THIS Code works when I write the join in the where clause
SELECT TOP (10)
[fact_gl_transaction].[job_code]
,[dim_supplier].[gtgetdisplaycaption]
FROM [DW].[dbo].[fact_gl_transaction], [CompassDW].[dbo].[dim_supplier]
where
[fact_gl_transaction].[dim_Supplier_key] = [dim_supplier].[dim_supplier_key]
''#########THIS Code does not work in TM1 when using left joins (but works fine in SSMS)
SELECT TOP (10)
left JOIN [dim_supplier] ON
Drill Throughs not accepting left Joins SQL- but accept where joins
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: Drill Throughs not accepting left Joins SQL- but accept where joins
Hello!
Reason here can be ODBC, not TM1. You can check it using Cubewise's ODBC-connect, for example: https://code.cubewise.com/open-source/odbc-connect/
Anyway, I prefer not to write complex queries in TM1, but to make views/functions on SQL-server side and use them in TM1 with simple query. Try this also
- gtonkin
Have you enabled the SQL loggers to see if there is any message coming back from SQL?
Could it be a context thing when running from TM1 that the left join does not know the table and schema i.e.
vs
left JOIN [CompassDW].[dbo].[dim_supplier] ON
- OLAP Product: tm1
- Version: TM1 Build Number: 11.8.01300.
- Excel Version: Version 2401
Solved - Thanks @gtonkin Joins now work with the full path.
and @Elessar, I think the approach keeping complex SQL out of TM1 is a good idea too, I will work towards this.
