Ultimate Long TM1 quiz
MarenC
Excel Version: Excel 2016
Re: Ultimate Long TM1 quiz
Post by MarenC »
MDX can be used in:
Dimension Subsets
Cube Views in PAW, PAX
In TI processes to create source views, build subsets.
In PAX or Perspectives dynamic reports, and probably Universal reports but not got around to those yet.
Just to be clear, re the last question, is that scenario theoretically possible and if so is there nothing that can be done? Asking for a friend....
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
- In PAFE, report definition for: Quick Report, Exploration, Universal Report, as well as parameter for functions e.g. TM1SET
- In PAW, report definition for explorations and all other visualizations
- In TM1 Server definition for subsets/sets and views, as well as input for various Turbo Integrator functions impacting subsets/sets and views
Take care.
Adam
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer:
MDX can be used in:
  1. Dynamic subsets
  2. MDX views
  3. TM1SET function
  4. Tm1ellist function (nobody has mentioned it, but it's a very powerful function, check it if you are not using it. For example, here I have described how to make dependent picklist using TM1ELLIST: https://advoynev.wordpress.com/2021/10/ ... -function/)
  5. CreateFromMDX, ReplaceWithFormats and other functions in PAX-API
Winner of this week is Adam for the most detailed answer (including the great new TM1SET function)
Question #15:
What will happen after you type "10>" in a cell?
Image 51.png (12.72 KiB) Viewed 1047 times
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
Adam
Version: 2.0.9.x
Post by Adam »
Nothing. You have to hit enter first. :-)
After you hit enter, 10 will replace each of the cells in that cell and to the right. In this case Total Year will now equals 120.
Take care.
Adam
MarenC
Post by MarenC »
Adam wrote: Sun Apr 14, 2024 12:45 pm Nothing. You have to hit enter first
Thats the cats job! :D
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer:
This will put "10" to current cell and all leaf cells to the right.
Winner of this week is Adam! (and nice catch with Enter)
Question #16:
What is the minimum dimension quantity in a cube?
Elessar wrote: Fri Apr 19, 2024 12:36 pm ...
Does this exclude the 1 dimension cube that TM1Fanboy hacked once? :lol:
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Wow, I'm not aware of this! How?
Adam
Version: 2.0.9.x
Post by Adam »
Two. However, I remember getting weird issues with some client apps, so I always do at least three.
Take care.
Adam
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer: 2
Winner of this week is Adam and he takes the lead!
Question #17:
Where are dimension attributes stored?
Image 52.png (13.18 KiB) Viewed 778 times
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Dimension attributes or element attributes? Attributes for elements of the primary hierarchy of a dimension are stored in a separate, two-dimension cube with name like "}ElementAttributes_<DimensionName>". The two dimensions are the dimension itself and a measures dim called "}ElementAttributes_<DimensionName>". Attributes for consolidated elements of alternate hierarchies are presumably also stored in a similar cubestore, but that's not viewable as a control object in PAW/Pafe or Architect. Dimension level attributes are stored in a cube called "}DimensionAttributes".
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer: In "}ElementAttributes_<DimensionName>" cube (Yes, I've meant element's attributes, thanks)
Winner of this week is ascheevel and he takes the lead!
Question #18:
Write a feeder for this rule. Note that Volumes are more frequently zeroes than Prices:
[‘Sales’] = N: [‘Volume’] * [‘Price’];
MarenC
Post by MarenC »
The feeder would be:
[‘Volume’] => [‘Sales’];
How did ascheevel overtake Admin in the lead, given he was in the lead the previous week? :?
Maren
Adam
Version: 2.0.9.x
Post by Adam »
MarenC wrote: Fri May 03, 2024 4:16 pm How did ascheevel overtake Admin in the lead, given he was in the lead the previous week? :?
Was thinking along the same lines, that next week you’re in the lead. Hahaha!
Take care.
Adam
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Leaderboard with points is on the 1st post, you can check there.
There were some errors there (too many of you are starting at "A"! This confused me a bit :) ), this is now fixed
