Pafe/PAW View - Auto Spread at Consolidated Level
chewza
Version: 9.5
Excel Version: 7
Post by chewza »
Hi there
In the cube viewer, capturing in data at a consolidated level automatically spreads the data down. Do you know if there is any way to prevent this?
Chris
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Pafe/PAW View - Auto Spread at Consolidated Level
Post by Elessar »
There are many options:
  1. Use CellSecurity to make consolidated cells 'READ"
  2. Use ElementSecurity to make consolidate elements 'READ" (better than point "1", because Elementsecurity is precalculated on SecurityRefresh, and CellSecurity is recalculated each time view is recalculated)
  3. Use CapabilityAssignments: https://blog.octanesolutions.com.au/wor ... ere-is-how
TM1 and Data Science blog: 7th article - Development requirements.
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
And if you want to keep Spreading enabled for some of the users, you should consider turning OFF this option
ProportionSpreadToZeroCells=F
By default this is turned on and in my experience this is dangerous
Ardian Alikaj
