Slice from Cube Viewer should goto a new book
Fairly simple one.
Currently a slice from the cube viewer in Pafe goes to the active book.
Request to be able to configure it so that it slices to a new book or have the full range of options that are available off the task bar.
https://ideas.ibm.com/ideas/PAOC-I-1269
Re: Slice from Cube Viewer should goto a new book
For now you could try adding the following to your tm1features.json:
r75_EnableSliceNewBook: true
Agree though that it should be a setting like it always used to be - my vote added...
Great thanks, excellent!
Scratch that, frustratingly that switch doesn't appear to work with the carbon viewer that is the default in Pafe 2.0.90
Damn, sorry - looks like the option is no longer available in PAfE 2.0.90 - possibly added for something internal and removed.
Holding thumbs for the Idea to get further consideration...
