Ever needed to recover a TM1 user's password when using native security i.e. mode 1?
The below script uses some undocumented functions to do the decryption.
These are not recognized in PAW but save and just ignore the error or use Architect.
Create a new process with a string parameter called pClient then add the following to the prolog section:
IF(pClient@='');
  pClient=TM1User;
ENDIF;
sKey='}@BujrF]uxPmWkqw}&t]MeOwNOx{tvYO,eD';
sPassword='';
sCipher=CellGetS('}ClientProperties', pClient, 'PASSWORD');
sCipher=EncodePassword(sCipher);
sModifier=INT(LOG(Long(sCipher)+1))-2;
sModifier=IF(sModifier<0, 2, 0);
nIndex=Long(sKey);
While(nIndex>2);
  If(Mod(nIndex-sModifier,3)=0);
    sCharacter=SUBST(sKey,nIndex-2,1);
    nCode=CODEW(sCharacter,1);
    sCharacter=CHAR( nCode- INT(nIndex/3));
    sPassword=sCharacter | sPassword;
  Endif;
nIndex=nIndex-1;
End;
TextOutput('password.txt',pClient, sCipher, sPassword);
Save and run the process, giving it a valid client or leave blank for your user.
After the run completes, view the password.txt file located in your data folder for the result.
BR, George.
Re: Ever needed to recover a TM1 user's password when using native security i.e. mode 1?
It works but I didn’t know that all my coworkers use the same password :shock:
