Creating MDX views for the data source to a TI process in PAW
Version: PAL 2.0.9.18
The title sums it up I guess. For all application cubes, create a view that can be used in the Data source.
It should avoid issues with messed up variable orderings in PAW.
## Create an MDX view for the data source of TI processes
vColumn_Selections = '';
vRow_Selections = '';
vView = 'ZZZ_tmp';
cMDX_Template_View = 'SELECT ' | vColumn_Selections | ' ON 0, ' | vRow_Selections | ' ON 1 FROM [' | vCube | ']';
cMDX_Template_OneElement = '{[%vDimension%].[%vHierarchy%].[%vElement%]}';
c = 1;
While( c <= Dimsiz( '}Cubes' ));
   vCube = Dimnm( '}Cubes', c );
   If( Subst( vCube, 1, 1 ) @<> '}' );
      # loop over the cube dimensions and add to the MDX view
      d = 1;
      While( d <= CubeDimensionCountGet( vCube ));
         vDimension = Tabdim( vCube, d );
         vHierarchy = vDimension;
         vElement = ElementFirst( vDimension, vHierarchy );
         If( d < CubeDimensionCountGet( vCube ));
            vColumn_Selections = vColumn_Selections | If( d = 1, '', '*' ) | Expand( cMDX_Template_OneElement );
         Else;
            vRow_Selections = Expand( cMDX_Template_OneElement );
         EndIf;
         d = d + 1;
      End;
      vMDX = Expand( cMDX_Template_View );
      ViewCreateByMDX( vCube, vView, vMDX );
   EndIf;
   c = c + 1;
End;
IBM Champion 2024
MarenC
Excel Version: Excel 2016
Re: Creating views for the data source to a TI process in PAW
Post by MarenC »
I only ever create views using TM1 cube views, not by MDX. Therefore, the title does not say it all, as it should have included MDX in the title!
I may find this very useful if I ever need to use MDX views as a data source. I will report back if that ever happens!
Maren
MarenC wrote: Tue Feb 21, 2023 12:22 pm Hi,
Maren
A data source in PAW that is a view. Do you have native views in PAW, then ?
IBM Champion 2024
MarenC
Post by MarenC »
Your title simply says a TI process in PAW, but the view doesn't have to be MDX does it? I presume you can create processes in PAW that behave the same way as cube view data sources in architect? I.e. not using ViewCreateByMDX
Maren
MarenC wrote: Tue Feb 21, 2023 12:43 pm Hi,
Maren
I see now that you can still have public native views as data source in PAW.
I thought it was only MDX views. I will change the topic title.
Can we still create a native view in PAW ? Through a TI process yes, but manually ?
IBM Champion 2024
MarenC
Re: Creating MDX views for the data source to a TI process in PAW
Post by MarenC »
Not sure about PAW but I think in PAX you can Save to Server, as opposed the Content Store.
Maren
