Generate MDX for subsets in Excel
Version: PAL 2.0.9.18
A small fun side project of mine :-)
Turn on the record function by clicking the cell next to "Record mode" if it's off.
Then click on the 1st column of the orange table to apply that particular MDX operation of the result in the yellow cell.
Fill out the 3rd column of the table when arguments are needed.
There's a bit of VBA code but I keep it deliberately small. The formulae in the sheet, notably, Lambda's and MAKEARRAY are much more interesting.
You do need a recent Excel version to use the file.
I like the input table on the right-hand side, whereby dynamic array formulas do things we could not do in the past.
You could extend it for instance by sending the MDX to the clipboard.
Enjoy.
MDX generator - Wim Gielis.xlsm
(27 KiB) Downloaded 428 times
IBM Champion 2024
20 Ton Squirrel
Version: Planning Analytics with Watson
Re: Generate MDX for subsets in Excel
Post by 20 Ton Squirrel »
Thanks very much for this, Wim. I'll peek into it and give some feedback this week.
War teaches us geography, getting old teaches us biology.
20 Ton Squirrel
I don't have some of these functions like MAKEARRAY so the workbook "breaks" on me.
I run Office 365, Excel is version 2002 (build 14931.20274). I see everyone on the internet gabbing about MAKEARRAY and LAMBDA functions but I don't have 'em. Now I'm jealous.
Looks like 2 years out of date-should be 2204 build 15xxx or something.
File, Account, Update? Or has IT blocked this?
Thanks for this post Wim, looks like some fun to be had.
20 Ton Squirrel
My company's IT is the worst. Figures I'm two years behind and screwed for it. >__<
gtonkin wrote: Thu May 12, 2022 7:35 pmThanks for this post Wim, looks like some fun to be had.
You can barely imagine all the singing and dancing when working on the file. Beers and confetti all around. You should have seen it to believe.
</20 ton squirrel mode=OFF>
IBM Champion 2024
20 Ton Squirrel
Wim Gielis wrote: Thu May 12, 2022 8:16 pm You can barely imagine all the singing and dancing when working on the file. Beers and confetti all around. You should have seen it to believe.
It would seem I'm getting a reputation on this forum. Meh, I'm shameless anyway. I'll own it.
«attempts to </20 Ton Squirrel Mode=OFF> but OH NO THE TAG IS BROKEN AND XML SPILLS ALL OVER THE FLOOR, STAINING YOUR CARPET»
Houston, we have an XML problem !
IBM Champion 2024
