Or at least those were my findings.
I was working with a very large dataset and calling the Expand function many times, the time saving I got by swapping it out was very significant.
If you are only running a small number of records or doing something on the prolog/epilog it is unlikely you will notice a big difference but for large data sets, you might manage to shave some minutes off longer running processes by getting rid of the Expand function.
It's a super simple example but you can see the differences in timing when running something like below (unhash 1 at a time and see the differences):
cOutputFile = 'C:\test.txt';
sString = 'String';
nNumeric = 1;
iCount = 1;
iMax = 10000000;
While ( iCount <= iMax );
#TextOutput ( cOutputFile, Expand ( '%sString%, %nNumeric%' ) );
#TextOutput ( cOutputFile, sString, NumberToString ( nNumeric ) );
#TextOutput ( cOutputFile, Expand ( '%sString%' ) );
#TextOutput ( cOutputFile, sString );
#TextOutput ( cOutputFile, Expand ( '%nNumeric%' ) );
#TextOutput ( cOutputFile, NumberToString ( nNumeric ) );
#TextOutput ( cOutputFile, Expand ( '%nNumeric%, %nNumeric%, %nNumeric%' ) );
#TextOutput ( cOutputFile, NumberToString ( nNumeric ), NumberToString ( nNumeric ), NumberToString ( nNumeric ) );
iCount = iCount + 1;
End;
Worth noting that in my actual process I was really using it for I had numerics that were not integers and I was just exporting to flat file to throw it all in a DB for further processing. I didn't need to worry about number formatting so NumberToString and/or Expand was sufficient.
I believe the biggest hit is the method used to convert numbers to strings in the Expand function is less efficient than that of NumberToString.
If you are only putting string variables in anyway there is a slight speed hit but not too significant... this make sense when you are essentially throwing an extra function into the mix that is arguably unnecessary.
It seems sort of obvious in hindsight that it would be slower but it's something I hadn't seen mentioned before or thought about until I needed to.
So thought I would share in case it could save someone else a little bit of a headache in the future.
