Pafe should always display what is in the cube when doing a retrieve.
If y'all could spend some time and review this RFE I'd be most greatful...
Simple put, formula based reporting in Pafe displays #N/A cube values as zeros, since this is by design it isn't a defect...
https://ibm-data-and-ai.ideas.ibm.com/ideas/PAOC-I-745
Thank you
Re: Pafe should always display what is in the cube when doing a retrieve.
Hi, this RFE has been marked as Not Under Consideration.
However the door is slightly open in that if the vote count goes up then it might be reconsidered.
Can I ask anyone that feels that the loss of error responses in the DBRW and other reports types is an issue to vote for the RFE please?
