Hi I am using below mdx to get a list of customers whose grade is D and and type is not 'DST1' from region 1
{Filter({TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER({[Customers SoldTo Only].[All Regions].[Region - 001]}, ALL, RECURSIVE )}, 0)},([AR HISTORY].([AR Measures].[Letter Grade],TM1Member( [Months].[Cognos Current Month Reporting].Item(0), [Months]))@='D') AND ([Customers SoldTo Only].[Type] @<> 'DST1'))}
Cube name is AR History. THere are more dimensions but I am looking only on month and letter grade.
Results not giving accounts that pass this condition.
Do I need specify values for mdx for all dimensions in the cube.
mdx returning incorrect results
- OLAP Product: Tm1
- Version: 9.5
- Version: PAL 2.0.9.18
Re: mdx returning incorrect results
Yes. Or, live with the fact that elements could be taken which you don't want.Analytics123 wrote: ↑Thu Jul 26, 2018 7:52 pm Do I need specify values for mdx for all dimensions in the cube.
For instance, element with index 1 in the dimension. So I would use values for the other dimensions too.
IBM Champion 2024
IBM Champion 2024
