TM1 Scripting
venureddy
OLAP Product: EXel
Excel Version: 15
TM1 Scripting
Post by venureddy » Tue Apr 17, 2018 2:57 pm
How can I modify text in generated section in Turbo Integrator.To write scripts
Re: TM1 Scripting
Post by David Usherwood » Tue Apr 17, 2018 3:00 pm
You can't.
If you don't want the code executed, either remove the mappings etc which generated the code, or wrap the code block as follows:
if(1=0);
# generated code
# end generated code
endif;
venureddy
OLAP Product: EXel
Excel Version: 15
Re: TM1 Scripting
Post by venureddy » Tue Apr 17, 2018 3:08 pm
Then Where Dimension sorting order is done
Version: PAL 2.0
Re: TM1 Scripting
Post by Wim Gielis » Tue Apr 17, 2018 4:45 pm
Add a function in the Prolog. DimensionSortOrder
http://www.wimgielis.com ==> 105 TM1 articles and a lot of custom code
Newest blog article: Looping over input files
