Using old clients with new planning analytics server
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Tue Feb 20, 2018 1:52 pm
Hi we are having client 10.1 and planning to connect with new planning analytics server . is this compatible and possible to use the old client with the new server . If anyone has achieved this please let us know .
Elessar
Re: Using old clients with new planning analytics server
Post by Elessar » Tue Feb 20, 2018 2:57 pm
Hello! What do you mean by "client"? Architect, Perspectives, CAFE, Perf. Modeler, Cognos Insight?
Usually, you can connect using old clients to new server, but you should turn ON supportpretlsv12clients parameter in tm1s.cfg: http://www-01.ibm.com/support/docview.w ... wg27048181
Sorry for my English ;)
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Tue Feb 20, 2018 3:23 pm
Yes we want architecture to connect . We are in 10.1 and trying to connect to IBM Planning Analytics .
I have added the entry in the config file
SupportPreTLSv12Clients=T and restarted the server .
But the server shows up but we could not login to it .
Elessar
Post by Elessar » Tue Feb 20, 2018 3:50 pm
What do you mean by "could not login"? The login window did not appear? Are there any errors?
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Tue Feb 20, 2018 4:02 pm
we see the server on double clicking on the server nothing happens, Will not show me the login credentials to enter or log me in through integrated login . But it works with the new client .
I alos have additional parameter IPAddress= T
in the config files.
ykud
Post by ykud » Wed Feb 21, 2018 6:31 am
I think PAL and TM1 10.x use different security certificates, can you check the versions / sizes of applix.ca file in bin64/ssl folder for PA and 10.1 client?
Difference in ssl certs would look exactly as you describe (see the server, cannot connect). You can enable the Login logging in tm1 server to see whether there's a SSL handshake issue.
Y
mberson
OLAP Product: Tm1
Version: 9.5.1
Post by mberson » Thu Mar 22, 2018 2:10 pm
Having this same experience as well. We often use the older version of Perspectives/Architect to connect to the new and old version of servers during an upgrade project. We opened a ticket with IBM and they stated that Perspectives/Architect 10.1.x and 10.2.x will not be able to connect to PA Local 2.0.x whc.
Haven't looked into the SSL certs yet, but that does make sense.
Any other feedback on this?
Matthew Berson
ACG TM1 Consulting
qml
Excel Version: 2007 - 2016
Post by qml » Fri Mar 23, 2018 5:34 pm
We have a PAL 2.0.4 server and our users are using a multitude of Perspective/Architect versions, going back as far as version 9.5.1. Here are the things that need to be done:
1) set the TM1 Admin server to support pre-TLS v1.2 clients via Cognos Configuration
2) add in tm1s.cfg:
SSLCertificateID=TM1Server
SSLCertAuthority=ibmtm1.arm
3) copy ibmtm1.arm file from PA2 installed directory to bin/ssl and bin64/ssl folders of Perspectives/Architect installation (or, really, anywhere else on the client machine or a network share accessible from it)
4) change in TM1 Options in Perspectives/Architect:
Certicate Authority: full path to the copied ibmtm1.arm file
CertificateID: TM1Server (case-sensitive)
Kamil Arendt
Post by tomok » Sun Mar 25, 2018 12:23 pm
2) add in tm1s.cfg:
Can I recommend we put this post in the Tips and Tricks section? Great info, thanks.
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Sun Mar 25, 2018 10:50 pm
2) add in tm1s.cfg:
Brilliant! Thanks for sharing. I got it working on my current 10.2.2 fp4 client to connect to PA2 server by changing the configurations above. Just need to remember to reboot your admin host after changing in Cognos Configuration.
A quick Q, is there any difference between the old client of V10 and PA client when connecting to PA2 server? Especially from end user point of view?
OLAP Product: TM1, CX
Version: TM1 10.2.2 PA 2.0x
Excel Version: 2010 2013 365
Post by lotsaram » Mon Mar 26, 2018 12:29 pm
