after Cube optimization -> TI won't run
Memo66
OLAP Product: IBM Cognos TM1
Excel Version: Excel 2010
Post by Memo66 » Mon Nov 13, 2017 8:09 am
i was wondering, if anyone had the same problem.
When i optimize the order of a cube, my Ti won't run when a consolidated Element is in my SourceView.
It runs successfully but it does not do anything.
Is this a bug?
We us the TM1 10.2.2 FP6 IF1
Memo
Version: 10.2.2., PAW
Re: after Cube optimization -> TI won't run
Post by Steve Rowe » Mon Nov 13, 2017 9:37 am
Are you 100% sure that this TI ran before the cube was re-ordered?
99.9% of the cases of TIs "not running" are because they have a C level in them and the view definition has Suppress consolidations checked.
Memo66
Post by Memo66 » Mon Nov 13, 2017 10:26 am
Hi Steve,
yes i am 100% sure.
That is now the second project we have this problem now
Post by Steve Rowe » Mon Nov 13, 2017 2:01 pm
Not an issue that I have ever come across so I guess it is could be a problem with the specific fix pack you are on.
Do you create the view from scratch in the TI or is it a permanent object that existed from before re-ordering? I always build from scratch, if you are working from a permanent object I'd suggest deleting and rebuilding the view.
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Mon Nov 13, 2017 9:54 pm
Please upload some images to prove that. It is hard to analyse from your words.
Memo66
Post by Memo66 » Tue Nov 14, 2017 2:14 pm
I don't know what image i can upload to prove it.
My Code to build the View:
sqView = 'z_akt_' | sProc;
viewdestroy (sCube, sqView);
viewcreate ( sCube, sqView);
sDim = '1';
sSub = 'z_akt' | sProc;
sElem = 'Elem';
IF(SubsetExists(sDim, sSub) =0);
SubsetCreate(sDim, sSub);
ENDIF;
SubsetDeleteAllElements(sDim, sSub);
SubsetElementInsert(sDim, sSub, sElem, 1);
ViewSubsetAssign(sCube, sqView, sDim, sSub);
ViewRowDimensionSet(sCube, sqView, sDim, 1);
sDim = '2';
sElem = 'Elem';
ENDIF;
ViewRowDimensionSet(sCube, sqView, sDim, 2);
sDim = '4';
sMDX = '{ HIERARCHIZE( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [4] )}, 0)} ) }';
subsetdestroy(sDim, sSub);
subsetcreatebymdx( sSub, sMDX);
ViewRowDimensionSet(sCube, sqView, sDim, 3);
sDim = '5';
sMDX = '{ HIERARCHIZE( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [5] )}, 0)} ) }';
ViewRowDimensionSet(sCube, sqView, sDim, 4);
sDim = '3';
sMDX = '{ HIERARCHIZE( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [3] )}, 0)} ) }';
ViewRowDimensionSet(sCube, sqView, sDim, 5);
sDim = '6';
sMDX = '{ HIERARCHIZE( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [6] )}, 0)} ) }';
ViewRowDimensionSet(sCube, sqView, sDim, 6);
sDim = '7';
sMDX = '{ HIERARCHIZE( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [7] )}, 0)} ) }';
ViewRowDimensionSet(sCube, sqView, sDim, 7);
sDim = '8';
sElem = 'Elem' ;
ENDIF;
ViewRowDimensionSet(sCube, sqView, sDim, 8);
ViewExtractSkipCalcsSet (sCube, sqView, 0);
DataSourceNameForServer = sCube;
DataSourceCubeView = sqView;
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Post by gtonkin » Tue Nov 14, 2017 4:48 pm
Should you be suppressing zeroes - you don't appear to be [ViewExtractSkipCalcsSet (sCube, sqView, 0); ]-this could be using too much memory - anything in your tm1server.log or tm1processerrors?
Post by Steve Rowe » Tue Nov 14, 2017 5:14 pm
You're using commands like ViewRowDimensionSet(sCube, sqView, sDim, 1); these are redundant when building a view to be used as a datasource (in my experience), on the basis that less code is better you could try removing them.
My personal preference would be to destroy the subsets if they exist rather than deleting all the elements.
I would also explicitly set all ViewExtract* items in the code and not rely on the defaults.
Also the obvious is sometimes easily overlooked, have you confirmed that there is really data where you think it should be?
Can you see the data point in the cube viewer if you select a single cell in the view with zero-suppression on? (i.e. are the N levels below the C level correctly fed? Do you have persistent feeders on? Have you deleted the .feeder files and restarted the instance? (This shouldn't be required but is worth a try!))
What happens if you leave the view behind and manually export it from the right click menu?
If this has happened twice then you should be able to establish a test instance so that you can raise a PMR with IBM, however they will probably tell you to move to IF7 or PA and retest, so if you are convinced this is a bug then your next step is probably an upgrade....
