Unable to pull views in TM1 Cafe
Posted: Fri Sep 08, 2017 6:58 am
by rni
When I try to pull some views from the package, It shows 'working' but then nothing appears (not even an error message). This happens only for some views and remaining are opening without any issue.
Also all the views open in TM1 web url. Only Cafe is causing trouble.
Anyone faced such a situation before?
Thanks in Advance
Re: Unable to pull views in TM1 Cafe
Posted: Fri Sep 08, 2017 10:25 am
by rni
The log file goes something like this:
# 2017/09/08 10:35:15.524
[Severity=Information]
[Exit] HideLoadingForm()
[Thread=1, Background=True, Pool=False]
[ms=0]
> Framework.AsyncCall.SendException(Object obj)
> Framework.AsyncCall.ExceptionCallback(Exception ex)
> Framework.AsyncItem`3.OnError(Exception ex)
> CognosOfficeReporting.CallWrapper`3.onError(Exception error, Tag tag)
< CognosOfficeReporting.CUILoadingForm.HideLoadingForm()
m_LoadingFormRefCounter = -1
Visible = False
# 2017/09/08 10:35:16.757
[Severity=Verbose]
[Entry] SelectNode(TreeNode node)
> CognosOfficeReporting.MultiSelectTreeView.OnMouseDown(MouseEventArgs e)
> CognosOfficeReporting.MultiSelectTreeView.SelectNode(TreeNode node)
# 2017/09/08 10:35:16.760
[Severity=Verbose]
[Entry] ToggleNode(TreeNode node, Boolean bSelectNode)
> CognosOfficeReporting.MultiSelectTreeView.ToggleNode(TreeNode node, Boolean bSelectNode)
# 2017/09/08 10:35:16.762
[Severity=Verbose]
[Exit] ToggleNode(TreeNode node, Boolean bSelectNode)
[ms=0]
< CognosOfficeReporting.MultiSelectTreeView.ToggleNode(TreeNode node, Boolean bSelectNode)
# 2017/09/08 10:35:16.764
[Severity=Verbose]
[Entry] OnBeforeSelect(TreeViewCancelEventArgs e)
> CognosOfficeReporting.MultiSelectTreeView.OnBeforeSelect(TreeViewCancelEventArgs e)
# 2017/09/08 10:35:16.767
[Severity=Verbose]
[Exit] OnBeforeSelect(TreeViewCancelEventArgs e)
[ms=0]
< CognosOfficeReporting.MultiSelectTreeView.OnBeforeSelect(TreeViewCancelEventArgs e)
# 2017/09/08 10:35:16.770
[Severity=Verbose]
[Entry] OnAfterSelect(TreeViewEventArgs e)
> CognosOfficeReporting.MultiSelectTreeView.OnAfterSelect(TreeViewEventArgs e)
# 2017/09/08 10:35:16.773
[Severity=Verbose]
[Exit] OnAfterSelect(TreeViewEventArgs e)
[ms=0]
< CognosOfficeReporting.MultiSelectTreeView.OnAfterSelect(TreeViewEventArgs e)
# 2017/09/08 10:35:16.777
[Severity=Verbose]
[Exit] SelectNode(TreeNode node)
[ms=17]
< CognosOfficeReporting.MultiSelectTreeView.SelectNode(TreeNode node)
# 2017/09/08 10:35:18.070
[Entry] ShowLoadingForm(Boolean allowCancel)
> CognosOfficeReporting.ApplicationView.CUIManager_MouseUp(Object sender, MouseEventArgs e)
> CognosOfficeReporting.ApplicationPresenter.View_DragEnd(Object sender, MouseEventArgs e)
> CognosOfficeReporting.UIManager.DragEnd(Object sender, MouseEventArgs e)
> CognosOfficeReporting.MapUI.DragEnd(ScreenMouseEventArgs e)
> CognosOfficeReporting.LoadingForms.CallWithRetry(In args, DoWork`2<Out,In> method, OnComplete`2<Out,Tag> complete, OnError`1<Tag> error, RetryTest retry, Tag tag, MethodInvoker onCancel)
> CognosOfficeReporting.CUILoadingForm.CallWithRetry(In args, DoWork`2<Out,In> method, OnComplete`2<Out,Tag> complete, OnError`1<Tag> error, RetryTest retry, Tag tag, MethodInvoker onCancel)
> CognosOfficeReporting.CallWrapper`3..ctor(CUILoadingForm form, In args, DoWork`2<Out,In> method, OnComplete`2<Out,Tag> complete, OnError`1<Tag> error, RetryTest retry, Tag tag, MethodInvoker cancel)
> CognosOfficeReporting.CUILoadingForm.ShowLoadingForm(Boolean allowCancel)
# 2017/09/08 10:35:18.080
[Exit] ShowLoadingForm(Boolean allowCancel)
[ms=8]
< CognosOfficeReporting.CUILoadingForm.ShowLoadingForm(Boolean allowCancel)
m_LoadingFormRefCounter = 1
# 2017/09/08 10:35:18.234
[Entry] HideLoadingForm()
> Framework.AsyncCall.SendComplete(Object ignored)
> Framework.AsyncCall.CompleteCallback()
> Framework.AsyncItem`3.OnComplete()
> CognosOfficeReporting.CallWrapper`3.onComplete(Out result, Tag tag)
# 2017/09/08 10:35:18.243
[ms=3]
m_LoadingFormRefCounter = 0
Visible = False
# 2017/09/08 10:35:18.248
> CognosOfficeReporting.MapUI.GetTreeNodeData_Complete(Object dragData, SheetCoordinate sc)
> CognosOfficeReporting.WorkbookMapper.DropView(CDLAnalysis report, SheetCoordinate sc)
# 2017/09/08 10:35:18.258
[ms=7]
