For anyone using bedrock or any other TurboIntegrator function library the current implementation of temporary subsets & views renders them for all intents and purposes completely useless as the temp object is only available within the scope of the process that created it and can't be accessed by a subsequent process within the same transaction. This means to use temporary objects all code to create views & subsets needs to be within each process which goes against the concept of having a reusable library of TI functions.
If you agree please vote here.
http://www.ibm.com/developerworks/rfe/e ... _ID=108021
RFE 108021: extend scope of temporary objects beyond creating process
- Version: PAL 2.0.9.18
Re: RFE 108021: extend scope of temporary objects beyond creating process
+1
IBM Champion 2024
IBM Champion 2024
