RFE 106604: DimensionDeleteAllHierarchy
mattgoff
Version: 10.2.2.6
Post by mattgoff » Fri Jun 16, 2017 3:24 pm
https://www.ibm.com/developerworks/rfe/ ... _ID=106604
What a better way to celebrate my 500th post than via documenting an RFE which will never be done....
It would be very handy to have a DimensionDeleteAllHierarchy command available in TI to be used when rebuilding a dimension, e.g. from a file. This can be done via the DimensionDeleteAllElments but this is risky since if there is an issue with the recreation process data loss can result. It can also be done by traversing the hierarchy manually but this is a tedious process and one likely only attempted by expert TI coders.
Some discussion here: http://www.tm1forum.com/viewtopic.php?p=65714.
Re: RFE 106604: DimensionDeleteAllHierarchy
Post by lotsaram » Thu Jul 20, 2017 8:43 am
good idea but I don't think the name of the function can be "DeleteAllHierarchy" as "Hierarchy" has a very specific meaning now as of TM1 v11
Version: PAL 2.0
Post by Wim Gielis » Sun Jul 30, 2017 7:09 pm
+1
http://www.wimgielis.com ==> 105 TM1 articles and a lot of custom code
Newest blog article: Looping over input files
