TM1 Developer - £550 per day - 6 months - Canary Wharf - Global Bank
Discuss / promote job opportunities for any OLAP / BI tool here.
vlad.stepanov
Version: TM1
Post by vlad.stepanov » Mon May 15, 2017 10:27 am
Hi to all TM1 specialists that are looking for a contract opportunity.
I am currently looking for a TM1 Developer for my client, an award winning Global Bank based in Canary Wharf.
They need someone to start ASAP initially for 6 months and they are ready to pay up to £550 per day.
What are they looking for?
  • At least 4 years of commercial experience as a TM1 Developer
    Up to date with the latest TM1 products & systems
If this is something you would definitely entertain, please send me your CV to vlad.stepanov@reedglobal.com
Paul Segal
Re: TM1 Developer - £550 per day - 6 months - Canary Wharf - Global Bank
Post by Paul Segal » Mon May 15, 2017 11:09 am
That last requirement might be a problem ;-)
Paul
vlad.stepanov
Version: TM1
Post by vlad.stepanov » Mon May 15, 2017 11:17 am
Paul Segal wrote:That last requirement might be a problem ;-)
So true.
Already had a candidate interviewing with the client and he was not keen on the Applix either.
What is the actual issue with the Applix? Why you(TM1 PROs) don't like it?
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Post by jim wood » Mon May 15, 2017 12:41 pm
So true.
Because Applix doesn't exist and hasn't existed for a while.
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
vlad.stepanov
Version: TM1
Post by vlad.stepanov » Mon May 15, 2017 2:06 pm
So true.
As I understand that the TM1 system was published by Applix Inc. and then Cognos acquired it and have rebranded the products, thus the systems were named Cognos TM1 and then IBM acquired Cognos....so logically it is IBM Cognos TM1?
TM1 is still TM1...isn't it? Even though it could be named Applix, Cognos or IBM.
jim wood
Version: TM1 10.2.2
Post by jim wood » Mon May 15, 2017 3:31 pm
vlad.stepanov wrote:As I understand that the TM1 system was published by Applix Inc. and then Cognos acquired it and have rebranded the products, thus the systems were named Cognos TM1 and then IBM acquired Cognos....so logically it is IBM Cognos TM1?
It would be like saying a new Think Pad is an IBM Think Pad even though Lenovo has owned the brand for a while. It has nothing to do with re-branding. Applix simply no longer exists. So you can continue to call it that if you want but you look out of date and a little daft.
JDLove
Post by JDLove » Tue May 16, 2017 10:10 pm
:-( 550 GBP pday was a common/avg rate in 2006/7 10 years ago ( in London ).
vlad.stepanov
Version: TM1
Post by vlad.stepanov » Thu May 18, 2017 8:58 am
JDLove wrote::-( 550 GBP pday was a common/avg rate in 2006/7 10 years ago ( in London ).
Wasn't around the recruitment domain back then :) but thanks for letting me know.
Where would I more likely find TM1 specialists? Anywhere particular except the job boards, job ads, LinkedIn, sourcing and etc.
Any help or guidance is much appreciated.
Version: PAL 2.0
Post by Wim Gielis » Sun May 21, 2017 9:28 pm
If you pay peanuts, you get ...
