CubeCreate and Logging Off
Version: 10.2.2., PAW
Post by Steve Rowe » Mon Aug 08, 2016 3:09 pm
In 10.2.20501.88 (10.2.2 FP5 IF1) I have noted that the use of CubeCreate results in a cube where the cube logging is explicitly set to No.
Believe this is a defect, though I'll probably be told just to set to the logging on after using cube create...One to watch out for if you are doing your development programmatically.
Cubes created manually in the server explorer default to blank, which is On. IMO CubeCreate should mirror this.
This resulted in large amounts of (already reconciled) data loss when the system I was building crashed :x
Your welcome!
tiagoblauth79
OLAP Product: Cognos BI and TM1
Excel Version: 10
Re: CubeCreate and Logging Off
Post by tiagoblauth79 » Thu Feb 02, 2017 4:38 pm
Good tip. Just to know: if I set the LOGGING to "YES" in the }CubeProperties as soon I created the cube in TI, does it works?
Thanks again.
Post by Steve Rowe » Fri Feb 03, 2017 3:30 pm
Yes that should would work as by then it is just a cube like all the others.
