RFE 85715 The TM1 Action buttons & ribbon buttons should not recalculate other sheets or books
Action buttons in Perspectives recalculate All worksheets in All open workbooks rather than recalculating just the current sheet as documented in the on-line and PDF documents and the on-screen text.
After a long PMR trail (since the 1st week in Jan) with IBM they have come back and confirmed the issue but have said that the functionality is correct and the documentation & GUI are wrong. Obviously very frustrating when they pull the "documentation is wrong / illogical behaviour is correct" trick, this should be treated as a defect.
See the below URL for a direct link to the RFE:
http://www.ibm.com/developerworks/rfe/e ... R_ID=85715
Please vote if you can as the current set-up makes action buttons pretty inefficient.
Thank-you!
Re: RFE 85715 The TM1 Action buttons & ribbon buttons should not recalculate other sheets or books
Steve Rowe wrote:Action buttons in Perspectives recalculate All worksheets in All open workbooks rather than recalculating just the current sheet as documented in the on-line and PDF documents and the on-screen text.
Thank-you!
Voted (after getting through the usual Internal Server Error; are they ever going to fix that??). I've also added it to my watchlist, since that apparently seems to matter in the rankings of requests. Currently it stands at 5 votes and 2 watchlists.
Voted too - 7 votes now.
