In the message error log file after I ran the TI process..I got the very common error..which I have seen many times...The error description is like this..."Invalid key dimension:month......or any other dimension name.....
What is the cause of this type of errror...?
What will be the resolution to these type of errors?
Inspite of this error sometimes data loads in cube but sometimes not...anyone know the reason?
I don't have a case right now..In morning same error I got...but data does not get loaded..when i got this error I changed the element type as string from simple..then also the same error..I was stucked at this point...
Invalid key dimension error
Re: Invalid key dimension error
It means an element your code states exists in a dimension doesn't exist in said dimension.
- sachin
- OLAP Product: Transformer,SSAS, EP, TM1
- Version: 7.3 2005 10.1 10.1.1
- Excel Version: 2013
In the row of your datasource, which your Data tab is processing, it encountered an element which does not exist in the corresponding dimension, yet. In your case it could be that you have data for Aug 2015, while Aug 2015 does not exist in the dimension. Or it appeared like 2015 Aug, while your element was Aug 2015 - there could be other scenarios as well. Or quite simply you mapped the element to the wrong dimension!dilip wrote:
Changing the element type will not help address your issue, not sure why you went that route. There are few ways to fix these kind of errors. In your data tab check for the existence of the element in the dimension before doing anything. If it does not exist, thendilip wrote:
- perhaps skip the row entirely
- move it to a common bucket which holds values of all such occurrences or
- simply insert the element using DimensionElementInsertDirect before doing any operation
- Version: 9.4
- Excel Version: 2003
Thanks sachin and declanr..for this post...
- Version: PAW 2.0.8
- Excel Version: 2019
Again this is not hard and fast rule , But the best practice is to have separate processes to handle metada update and data load.ThanksA good idea is to build your metadata first before loading your data into the cube(s). This is assuming whatever job that produces your data is taking care of master tables from which your metadata is built!
Is it?BariAbdul wrote: Again this is not hard and fast rule , But the best practice is to have separate processes to handle metada update and data load.Thanks
I tend to find the phrase "best practice" when spoken by people in a TM1 context can often be a slight exaggeration.
In this case it's probably a "fair comment" but I would still go with a horses for courses approach.
