MDX , create subset by value in other cube
sk1080in
Version: Planning Analytics
Post by sk1080in »
I have a value written in one of the lookup cubes (Example: W010215, W050115, W040115) and on the basis of first 3 characters want to create subset in another dimension which has values like W01, W02, W03....
So whatever the value is in lookup cube, should become the basis for subset in another dimension.
Can somebody guide me if this is possible.
rmackenzie
Re: MDX , create subset by value in other cube
Post by rmackenzie »
TM1 supports the LEFT function - it may likely be un-documented and differ between versions etc.
Anyway, you can do something like this:
{TM1FILTERBYPATTERN(
  {TM1SUBSETALL([Interesting W Things])},
    LEFT(
      [Control Cube].(
        [Control Parameter Dimension].[Some Parameter],
        [Control Measure Dimension].[String]
      3
Note the concatenation of the wildcard character (*) at the end of the filter.
Robin Mackenzie
sk1080in
Post by sk1080in »
Thanks a lot, it is working fine, however giving all levels of elements starting with the 3 characters selected. Can it be restricted to 0 Level only ?
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
sk1080in wrote:Thanks a lot, it is working fine, however giving all levels of elements starting with the 3 characters selected. Can it be restricted to 0 Level only ?
You can embed the above statement with TM1FILTERBYLEVEL and that will give you only level zero elements
Ardian Alikaj
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
You are right, it's not documented anywhere.
BTW RIGHT function is supported too (not documented of course) :lol: :lol: :lol: :lol:
sk1080in
Post by sk1080in »
Thanks a lot everyone, it has worked for me. Last question...Can I pick something from between as well ? Like start from 4th Character and pick 2 Characters ?
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
To my knowledge (and from testing) MID function is not supported in TM1 MDX.
rmackenzie
EvgenyT wrote:To my knowledge (and from testing) MID function is not supported in TM1 MDX.
But you can achieve the output of a MID if you have LEFT, RIGHT and LEN. E.g. this will work:
  {TM1FILTERBYLEVEL(
    0
  LEFT(
    RIGHT(
      [Control Cube].(
      LEN(
        [Control Cube].(
      ) - 4 + 1
    ), 2
Robin Mackenzie
sk1080in
Post by sk1080in »
Brilliant Solution, Thanks for that. You are a Star.
