Create a pick list
- OLAP Product: Cognos
- Version: 9.5.1
Create a pick list
Hey every one,
I'm trying to create a pick list but I didn't success. Someone could help me by giving me a method to follow ?
Thank's a lot
Thank's a lot
Re: Create a pick list
What did you try? What sort of picklist are you trying to create (static, dimension based, subset based, variable upon other data input to the cube)?
As a starting point try the developer guide:
http://pic.dhe.ibm.com/infocenter/ctm1/ ... 23456.html
- Version: 9.5.1
First of all thanks for your response. I'm trying to create a picklist based on subset. I have a dimension named "RUBRIQUE" which has a list of measure ("Garanty","blabla",...). I have a cube with a dimension named "MEASURE", this one has a measure named "RUBRIQUE". I would like to put in this measure the content of my dimension "RUBRIQUE"
If you had checked the developer guide link that I suggested you would have seen that you need to:beber005 wrote:First of all thanks for your response. I'm trying to create a picklist based on subset. I have a dimension named "RUBRIQUE" which has a list of measure ("Garanty","blabla",...). I have a cube with a dimension named "MEASURE", this one has a measure named "RUBRIQUE". I would like to put in this measure the content of my dimension "RUBRIQUE"
- Create a string attribute on your measures dimension called "PickList"
- In the picklist attribute against the measure "RUBRIQUE" put "Dimension:RUBRIQUE"
- Version: 9.5.1
I have already read this guide. But your suggestion dosen't work. Maybe I do a bad thing when I create a string attribute on my measure.
Is your measures dimension the last dimension in the cube? And is the element within it specified as a string element?beber005 wrote:I have already read this guide. But your suggestion dosen't work. Maybe I do a bad thing when I create a string attribute on my measure.
Also If you specify exactly what you have tried and exactly how it doesn't work you will get to the solution much quicker.
- Version: 9.5.1
Ok !!
First of all, I created a dimension "RUBRIQUE". In this one I have create a subset wihch one contains my entire measures. After that, I have created a cube named "PickList_NRE" with 3 dimensions :
- RUBRIQUE
- CUTOMER
- PICKLIST (this one is already created in my TM1's structure and it is already used by other cube)
In this cube I would like to write a rule to specify that my dimension "RUBRIQUE" contains a list of data. I used this formalism :
But all this doesn't work
- RUBRIQUE
- CUTOMER
['RUBRIQUE'] = S:
'subset:RUBRIQUE:Rubrique tot'
- ioscat
- OLAP Product: Contributor
- Version: 9.5.2 10.1.1 10.2
- Excel Version: 07+10+13
You ought to not create picklist cube manually. Create it with right click - create picklist cube
Picklist cube allows you to create a picklist for a cell. If you need to create picklist for a column (for a measure), you should use elementattributes cube
- Version: 9.5.1
Yes I want to create a pick list for a cell. Sorry if I did not express myself properly
- ioscat
picklist cube must be named somthing like }Picklist_CubeName
it should be created be TM1 when you right click some cube and choose "create picklist cube"
- Version: 9.5.1
Thanks a lot, I found the solution and I'll join you on what you say, this the solution. Here's a link to the next to be blocked : http://pic.dhe.ibm.com/infocenter/ctm1/ ... 23456.html
Thanks to the community
