Hi!
I am in the process of revising some TM1 sheets.
Is it possible to force a line break on an action button?
For example, I have a report "Management report".
The button becomes very wide. I would rather have a square with two lines:
"Management
Report"
Is this possible with Perspectives and TM1Web or do I have to solve it with Pafe and a graphic above the button?
Thanks for any ideas!
Many greetings
orlando
Actionbutton with more than one line
- gtonkin
Re: Actionbutton with more than one line
Not sure that you can on the Perspectives based action buttons.
I have tried macro code to set the caption with a vbLF, vbCr and vbCRLF between words but the Action Button which appears to be an object in a drawing object does not seem to render this.
On PAfE, this seems to be easy to do - enter your text in a cell using Alt+Enter for the new line then copy contents of the cell to your Action Button.
Underlying objects are different which why it appears to work.
For interest I use the following code to loop through my Action Buttons and adjust sizes, positions etc.
You could tweak the to include TIButton.DrawingObject.Object.Caption to fiddle with the Caption
Note: I do have some constants defined for the button width and height.
Not sure that it will necessarily help you but you never know...
Sub FormatTIButtons()
Dim TIButton as Variant
For Each TIButton In ActiveSheet.Shapes
If TIButton.Type = 12 Then
If Left(TIButton.OLEFormat.progID, 5) = "TM1XL" Then
TIButton.Top = (TIButton.TopLeftCell.Height - TIButton.Height) / 2 + TIButton.TopLeftCell.Top
TIButton.Left = TIButton.TopLeftCell.Left + 1
TIButton.Width = iButtonWidth
TIButton.Height = iButtonHeight
End If
End If
Next
End Sub
- orlando
- Version: PAL 2.0.8
thanks for your reply.
I give Pafe a try - have to change my main TM1 to Pafe/PAX till end of the year anyway....
Best regards
orlando
Best regards
orlando
Just a thought on this, in Perspectives can't you add an image as the background of an action button?
Create what you want the button to look like in Excel, take a screenshot and save it as an image and then try using that for the Action Button background.
I think it might still require you to put text in the button, so you could try a single dot and format it to be the same colour as the background behind it.
- garry cook
- Version: Various
- Excel Version: Various
Other option to render appropriately in TM1Web specifically is to do it in reverse and create a fully transparent Action button sized the same as the background image. Place this over the background image you want to use if you're dynamically changing the background icon or underlying text, etc.
Used that previously to make TM1 linked graphs "clickable" in Web to the end user to navigate through to related websheets. They have no idea they're hitting an action button, it worked quite well from a web front end POV for the user.
