Feeders not being fed for consolidated elements
spartan
OLAP Product: IBM cognos
Post by spartan »
Hello All,
I have a consolidated element as A001,B001 and its leaf elements as A001X001,A001X002 etc., when i am making zero
suppression the value in A001X002 is getting lost.But the values in B001X001,B001X002 are populating fine.Both the
consolidated elements are in same cube and have same rule file.
But B001 consolidated elements are working fine and A001 consolidated elements are lost when zero suppresion.
When I trace the feeders B001 element values are populating and A001 values are showing as not fed.
I am using 10.2.2 version.
Could anyone help me to solve this problem.
Admin note: Moved to the correct forum.Please do not post TM1 / Planning Analytics issues in General
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: Feeders not being fed for consolidated elements
Post by ascheevel »
It looks like you've confirmed that leaf elements of A001 aren't fed, the way to fix this is to feed them. You'll need to review the rule that applies to those elements and then ensure there's an adequate feeder from an intersection that's referenced by the rule.
