Dimension subset editor in TM1 Perspectives
In TM1 Perspective Report I tried to open up the dimension subset editor, but not able to. (no error msg though )
what may be the reason that i am not able to go into the subset editor?
Please share your thoughts if you have idea on this. Thank you!
- Version: PAL 2.0.9.18
Re: Dimension subset editor in TM1 Perspectives
It could be that the Subset Editor is shown (or TM1 tries to show) on a second monitor.
Do you have such a setup of a dual monitor ?
IBM Champion 2024
IBM Champion 2024
no , it's not related to the monitor.
I believe the issue is within the excel sheet subnm formula (TM1 perspectives).
Able to open the same report and nable to access dimension subset editor from another instance on the same server.
- Version: 10.2
In my opinion, SUBNM formulas in TM1 Perspectives never work properly. I usually get Visual Basic Error when I double click on a SUBNM cell from Perspectives so I do all my testing from TM1Web
I wouldn't say "never", but you are right, we all have double-clicked SUBNM's just to end up with no ribbon icon labels. Or with the cell showing the SUBNM formula as text rather than the result. Or with Excel crashing. Or ......... just add to the list yourself.
IBM Champion 2024
IBM Champion 2024
- Steve Rowe
The other reason that the subnm double click often fails is that people often try and reference another cell to get the server name, this will stop the double click from working.
=Subnm("Server:Dimension",....
works
=Subnm( A1 & ":Dimension",....
will not work
works
will not work
Just tested it and it works fine. PAL 2.0.4, Excel 2016. And I should say, it would be a shame if this would not work. How else are we supposed to keep the websheets maintainable ? I.e. TM1 servername in a named range or cell.Steve Rowe wrote: ↑Fri Jun 08, 2018 11:24 am The other reason that the subnm double click often fails is that people often try and reference another cell to get the server name, this will stop the double click from working.
works
will not work
IBM Champion 2024
IBM Champion 2024
- Steve Rowe
AS Wim points out this behaviour does vary by version....
- Version: 10.2
Also another reason is Protecting the Sheet.
If you procect the sheet, you have to make sure that all the cells with SUBNM formulas are unlocked, otherwise you get a VBA error when you double click and after that point, you have to re-launch Perspectives.
But in TM1Web, the SUBNM will work fine even if you don't unlock the SUBNM cells
Thank you all for the replies.
Based on your thoughts and recommendation I did check the subNM formulaes and noticed that they are pointing to another server , I set it to the correct server. Thank you All..
